RV.Net Open Roads Forum: Truck Campers: Michelin XPS Traction failure
 > Michelin XPS Traction failure
Truck Campers Related Tips
FF1063
Posted: 10/26/09 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
I found I had a flat on the rear inside dual, probably flat for some time as I rarely check. Could not notice visually, and unloaded ride was normal. I put 60 psi in it and noticed some sidewall expansion issue, so I knew it was shot. I left it in my bed under the tonneau cover and it blew today. I'm glad I was not around when it did as it really damaged my tonneau, it's heavy aluminum frame, and two clamps. I'm also glad I was not hauling the TC with the tire on the front axle. I don't think I would ever air these commercial tires down for the beach.
98 Ram 3500 12V-CTD / 05 Arctic Fox 990
kohldad
Goose Creek, SC
Posted: 10/26/09 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
That's the first problem I've heard with an XPS tire.
I'm curious as to manufacturer date and tread condition.
Suggest you get the lot number and send an email or call customer to Michelin as they are probably interested in it and may want to make sure they get the core back for analysis.
Photo Albums (Congaree NP added 12/09/09)
2004.5 Ram 3500 4x4 Quad-Cab SRW CTD 6-spd
2004 Lance 815
1982 CJ-8 Scrambler - going, going, anyone
Loving wife, two horse crazed teenage daughters, two horses, two cats
Matthew_B
The boonies near Dallas, Oregon
Posted: 10/26/09 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
My first response is
That's what I have on the front of my truck right now.
As kohldad stated this happening is rare with XPS tires. Even more surprising is that it happened under no load while sitting under the canopy.
The XPS tires have steel wall in them. That's quite a rent to have ripped through the steel wall so I really wonder what happened to the tire.
Raften
Northern Calfornia
Posted: 10/26/09 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
My guess is that tire got driven for quite a lot of miles with next to nothing as far as air pressure in it.
Matthew_B
Posted: 10/26/09 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
X2
Dewclaw
Oregon
Posted: 10/26/09 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
This is a big surprise to me. I used XPS traction for years and have recommended them to others. Never a problem with them. I guess any product can have a failure, no matter how rare.
BTW, this is an opportunity to mention a good blowout safety video that has been posted on RV Net before. http://www.youtube.com/watch?v=lkwOE1yKY5c
2008 Northern Lite 9-6 Q Classic SE
2007 GMC 2500HD
fueling around
NW MN
Posted: 10/26/09 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
You can see the far sidewall pretty clear through that blow. It doesn't show the typical run on flat damage which I suspect was due to the training wheel taking the load.
Curiously, I saw a Kumho passenger tire with the exact failure today. I put new tires on the Mommy van and a tire failure came in the shop. The Kumho also blew standing still. About a cup of crumbled rubber inside the tire, but not typical damage on the inner sidewall from running low or flat. It wasn't run flat, but had been a problem child for not balancing well.
John
1997 Dodge 2500 CTD
1989 Cascade 8½ Self-contained Truck Camper
?? Eureka Timberline 4 tent
FF1063
Posted: 10/27/09 04:55am Link  |  Quote  |  Print  |  Notify Moderator
I had my 6 XPS's installed by Costco in 6/03, so I'm out the luck on their 5 yr road hazard warranty I have about 75K on them now. I think riding with the tire at zero psi really caused the problem. Even though it did not take any load, I think constantly spinning a tire at 60+ mph empty could have damaged the sidewall belts ?
mkirsch
Rochester, NY
Posted: 10/27/09 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Either running it flat, or a manufacturing defect that made it past quality control, is what caused the blowout.
You said the sidewall looked funny when you pumped it up... I would've let the air outta the tire at that point, instead of letting it blow the tonneau off my truck Hindsight is always 20/20...
