mabryoso1
north carolina
Good Sam RV Club
Have a 2005 southwind .Its winterized and under cover. Thinking about leaving it hook up to elec. topped off the batteries with water etc. going south
up 5 months and I won't be able to check on it april 1st. Theres nothing on its just to keep the batteries charged up. Thoughts. thanks
4*phun*2
Canada
I would use a Battery Tender instead.
Glenn & Karen
'06 F350 4X4 Lariat CC LB DRW (nice hips)
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
pulsar
Lewisville, NC
Good Sam RV Club
Moved from Forum Technical Support to Tech Issues.
djevans
Tennessee
Our converter is too aggressive to leave unattended for 5 months - I agree with the battery tender
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - Saturn VUE
350hp Cummins ISC
- - - P i c t u r e s - - -
I'm confused, WAIT! Maybe I'm not!
suchristo01
San Diego, CA
If your Southwind has a Power Dynamics 9200 series converter you have a smart charger already. If it has the 9100 series check to see if the Charge Wizard was installed. That makes it a smart charger. If not get one at http://www.bestconverter.com around $25.00. And your Battery Control Center should keep your chassis battery up as well. Ot boosts at 14.2v until the bats are at 90%, finishes the charge at 13.6v thrn floats at 13.2v. Every 2o hours it desulphates at 14.2v for 15 minutes then goes back to 13.2v.
Tommy USMC,Susie USN Ret, Dog Buddy
2000 Fleetwood Flair 25F WH P32 7.4L 19.5"
2002 Ford Ranger XLT 3.0L 5 Spd Man
Blue Ox Base,Aventa II,4 PIN Locks
US Gear UTB, Power Gear Man Lev, Onan 4KW
Tent,GP Tent,Tent Trailer,2 Class A's
Are We There Yet?
Bobbo
Memphis, TN
Good Sam RV Club
It depends on your converter. If it is a Parallax/Magnatek, then ABSOLUTELY NOT! If it is one of the 3 stage converters, it would be OK.
Bobbo, Linda and the furry kids (German Shepherd and German Shepherd mix)
2007 Winnebago Outlook WF331C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
2oldman
Indio CA
Stay plugged in in storage?
Stay plugged in roast batteries?
Bumpyroad
Virginia
I keep mine plugged in and have it on a timer so it comes on for an hour or so each day. do not use a fancy new digital timer however.
bumpy
You can't take the Fisherman out of this Camper
Ontario, Canada
Good Sam RV Club
Bumpyroad wrote: I keep mine plugged in and have it on a timer so it comes on for an hour or so each day. do not use a fancy new digital timer however.
bumpy Ditto. But I do use a digital timer because the load is pretty small. Only the battery charger and a night light so I can see when it is on (parked beside the house). The digital timer has an internal battery so that the timer stays on schedule... even when the power is off for any length of time. I will be leaving mine for over 3 months when snowbirding this winter. I intend to do the same with my Florida trailer (for 9 months!) next year... but I will just put the battery on a small trickle charger, after disconnecting it from the trailer charger, and I will put the timer on for only a couple of hours once per week.
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: 2002 Cougar 276EFS & 2005 Laredo 29GS; 2002 GMC 2500HD Ext Cab 4x4; (Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
