Dihi 5
Brownwood, Texas
Good Sam RV Club
I have a 50 amp outlet at my home. Can I use an adapter to go from 50 amp to 30 amp without causing any damage? Thanks
2oldman
Indio CA
Got a VOM?
bob213
Fresno, CA
Good Sam RV Club
Yes. Walmart has a pigtail to change from 50 to 30. So does Camping world or any RV supply. Good to take with you when you camp. Sometimes the 50 amp outlet may be in better shape than the 30.
On edit.........Just make sure your 50 amp outlet is 110 NOT 220!!!
edited 10/28/09 09:42pm by bob213 *
djevans
Tennessee
possibly - what kind of 50 amp outlet? (How many "holes" does it have for the plug to plug in to?)
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - Saturn VUE
350hp Cummins ISC
- - - P i c t u r e s - - -
To live a creative life, we must lose our fear of being
rong… wong… worng… argh!… of making misteaks.
- - Anon
Chuck&Gail
In the Colorado Mountains
As said above, maybe. I have a 50 amp outlet in my house that would NOT be usable with the standard RV dogbone adapter. If you do not know exactly what wire size is used for common, IMO call an electrician to remove the socket and look.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
PapPappy
Wilmington, NC
Good Sam RV Club
Having a 50A outlet for your dryer or maybe a welder would have 220VAC, which won't work for you, unless the wiring is changed at the box.
You can convert that to a 30A outlet, by changing it from 220VAC to 120VAC, and replacing the "50A" outlet with a 30A outlet. The money you would spend for a "pigtail" would pay for the new outlet.
If you are not familiar with electricity, you will probably want to get a licensed Electrician in to make the change for you.
Bill & Claudia / DD Jenn / DS Chris
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie & Beau
RIP: Cookie (Sheltie) & Gidget (Lab-mix) over the Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
smkettner
Good Sam RV Club
Yes, no worries.
If the standard 50/30 RV adapter works it is fine. (NEMA14-50 to NEMA30-TT)
edited 10/29/09 10:11am by smkettner *
Bumpyroad
Virginia
it depends on the 50 amp outlet.
bumpy
Kirk
Livingston, Texas.
The key is what outlet do you have there. In general, if the standard adapter that you buy at Wal-Mart or the RV store will plug into it to connect to your 30A cord, then it should be safe. A 50A RV outlet is what is known as a 120/240V-50A outlet and if properly installed, it is the only plug with the pin configuration that your RV adapter will connect to.
To be safe, the only thing to do is to connect the adapter to the 50A outlet and then measure from pin to pin to check for proper voltage. Measuring on your adapter once connected it should read 120V from the hot to either the ground pin, (the round one) or to the neutral. From neutral to ground should read 0V or very nearly so. That is the only way to be sure.
Outlets should always be properly wired, but electricians do make mistakes and amateurs sometimes try and fix things they don't understand.
Good travelin! ........Kirk
Professional Volunteer
www.adventure.1tree.net
Bobbo
Memphis, TN
Good Sam RV Club
If it is a 3 pin 50 amp outlet, not without much modification. If it is a 4 pin 50 amp outlet,probably.
Bobbo, Linda and the furry kids (German Shepherd and German Shepherd mix)
2007 Winnebago Outlook WF331C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
