RV.Net Open Roads Forum: Tow Vehicles: Steering column "clunking" sound. Why???
Search only in Tow Vehicles
 > Steering column "clunking" sound. Why???
Tow Vehicles Related Tips
DOTLDaddy
Camp Canine, Union / Ballwin, MO. U.S.A.
Good Sam RV Club
Posted: 10/29/09 05:27am Link  |  Quote  |  Print  |  Notify Moderator
My '03 GMC Sierra has developed an intermittent "clunking" sound when turning at very low speed on my rough, gravel driveway. Mostly happens when I am turning the truck to position it to back into my garage.
Any ideas???
Walter & Garland - Camp Canine caretakers
Gen. Gretchen - 5 y.o. GSD - Special Forces/Seal/DOTL Cloudbusters
Gen. Missy - GSD/Aussie - Special Forces/DOTL Rainbow Division
2003 GMC Sierra 2500HD
2008 Puma 25RBSS TT
Capt Skup
Southern Maryland/Nantucket
Posted: 10/29/09 05:31am Link  |  Quote  |  Print  |  Notify Moderator
Ball joints, tie rod ends, steering box, steering column u-joint?? Time to do some basic investigating.
Capt Skup
AD-1(AW)USNRet.
Wonderful Wife,3 Daughters,2Goldens Gus&Riley
"Never get in a battle of wits with an unarmed man"
'08 F-450 Lariat 4x4
'08 Honda Odyssey EX-L
SunlineF281SR
SeaRay215EC
http://community.webshots.com/user/CaptSkup?vhost=community
Geozzz
South Jersey
Good Sam RV Club
Posted: 10/29/09 05:34am Link  |  Quote  |  Print  |  Notify Moderator
add shock bushings
Kathy & George Zimm
Mickleton NJ
2006 Coachman Epic and 2 Shelties
b_salgado
Salisbury ,NC,USA
Posted: 10/29/09 05:38am Link  |  Quote  |  Print  |  Notify Moderator
Check your sway bar end links also.
04 Lariat Supercrew 4x4,5.4,3.73, Edge tuner, flowmaster duals
06 Trail Bay 31BH, nicely optioned
Equal-i-zer
Prodigy
Follow vehicle, 05 KIA Sorento EX for the golden retrievers.
jenoble99
Indiana
Posted: 10/29/09 05:41am Link  |  Quote  |  Print  |  Notify Moderator
We had an '02 Tahoe that did the same thing. I would be willing to bet it's the steering shaft that connects the steering wheel to the gear box. This is a common GM problem with trucks of this vintage. The only fix I am aware of is replacement. But it will eventually do the same thing. Though I believe a few had some luck with cleaning and greasing the shaft. If it is the steering shaft then it's nothing to worry about, just a little annoying.
DOTLDaddy
Good Sam RV Club
Posted: 10/29/09 05:48am Link  |  Quote  |  Print  |  Notify Moderator
jenoble99 wrote:
... I would be willing to bet it's the steering shaft that connects the steering wheel to the gear box. .
The sound does seem to be coming from the steering column area.
1mtnman
Colorado
Posted: 10/29/09 05:50am Link  |  Quote  |  Print  |  Notify Moderator
Gm truck products are very prone to developing the problem you have with your vehicle. It is a problem with the intermediate shaft in the steering column. Over the years there have been many attempts by GM to correct the problem and they finally have come up with a cure. The shaft is replaced by a new engineered replacement and that takes care of the rattle/loose sounding condition. I don't know what your luck will be in trying to get GM to replace it as they did with many others a few years ago. You probably will have to pay for the replacement. The regreasing technique they used prior to the new shaft was only a temporary fix so don't let they con you in to that.
http://i43.tinypic.com/n1qwas.jpg
Thunderbolt
North Branch, Mn USA
Posted: 10/29/09 06:09am Link  |  Quote  |  Print  |  Notify Moderator
It is the intermediate steering shaft. Very common problem on GM trucks as far back as mid to late 90's.
Bryan
2003 2500HD Ext. cab short box
6.0 liter 4.10 gears, Nelson performance PCM
98 K1500 4x4 heavy duty 1/2 ton
6,600lb GVWR 5,280lbs on the scale empty
14 bolt rear diff. 3:73 , Tranny and oil coolers
280,000 miles still purrin' like a kitten
frank henn
jackson, mississippi
GM has had a problem with the intermediate shaft on a whole bunch of their units. At on time the fix was to pull the shaft pack it with a HD white grease and put it back in. two years ago the redesigned the shat, and seems to have cured this problem. Note it is not a safety issue but an annoying noise. My DW Buick 2006 model just started to do it, the car has only 40K on it I will replace it, because it bothers her, I will just turn down my hearing aid
Thud
MS
Posted: 10/29/09 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Yes, it is the steering shaft and as others have said, nothing to worry about except for the annoyance. My 04 started doing it at about 20,000 miles and I put off getting it serviced and you know what? It quit making the noise about 10,000 miles later and now it is silent again and drives like new, so I'm not gonna mess with it.
