RV.Net Open Roads Forum: Tech Issues: honda 2000 generator
 > honda 2000 generator
Tech Issues Related Tips
ttyuille
HOME
Good Sam RV Club
Posted: 10/29/09 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyonw know if this generator will run a standard travel trailer air conditioning unit
DesertHawk
Las Cruces, New Mexico
Posted: 10/29/09 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
It will run the one on our Scamp, but I do not consider it a standard AC. It is a small unit as is the Scamp. It would be my gut feeling for a more standard sized unit you would be better off with a Honda 3000. IMHO.
DesertHawk - Las Cruces, NM USA
2005 16' Scamp Molded Fiberglass Travel Trailer
Side Dinette, Front Shower & Head
2009 White Ford F-150 Reg. Cab
Long Bed with A.R.E. Molded Fiberglass Topper
Wheresoever you go, go with all your heart. -Confucius
old guy
Oregon (pronounced Or e gun)
Posted: 10/29/09 11:32pm Link  |  Quote  |  Print  |  Notify Moderator
as per posts on this forum the answer is NO. the A/C has to be smaller than a 13K. if you connect two 2000's together the answer moves up to YES.to run an A/C you will need something over 3000K gen set.
javaseuf
California's Gold Coast
Posted: 10/29/09 11:55pm Link  |  Quote  |  Print  |  Notify Moderator
Some here have had favorable results using the Honda 2k genny with a 13.5 roof-air when the Supco hard-start kit is installed.
I use a Yamaha 2400 genny and with the Supco kit, it runs my 15k air.
Even though the Yamaha is heavier, I believe it's benifits outweigh the extra weight.
Steve
2007 Springdale 291RKL
2009 F150, 5.4 ltr.
1986 Palomino Hard-Side PUP
"Nobody knows how we got to the top of the hill, but since we're on our way down, we might as well enjoy the ride". ("The Secret Of Life", James Taylor).
Wayne Dohnal
Bend, OR.
Posted: 10/30/09 12:02am Link  |  Quote  |  Print  |  Notify Moderator
Numerous people, including myself, have reported on this forum that they routinely run a 13,500 btuh air conditioner with a single eu2000i. The highest success rate appears to be with Brisk Air units. To be successful you have to tightly manage the RV's AC loads, which is not for everybody. The big problem is that you don't know the answer without trying it on your own rig, so buying an eu2000i with the need or intent of running the air conditioner is pretty risky. For myself, I didn't expect it to work and it wouldn't have been a hardship if it hadn't. In a few other cases, the users have dual eu2000i generators and tried with one just for the heck of it and it worked. In other cases it didn't.
2009 Fleetwood Icon 24A
LinkPro battery monitor
EU2000i generator
TomG2
Central Illinois
Posted: 10/30/09 05:29am Link  |  Quote  |  Print  |  Notify Moderator
This subject is covered thoroughly about every six weeks and the answer is usually "Yes". I, like most folks, run my Dometic 13,500 btu AC with no problem. The only requirement is that other loads like water heaters, microwaves, converters, etc. must be off at the time. Mine draws about 10.5 amps which is well within the normal operating range of Honda 2000i. It may not do so well at 10,000 ft elevation or if I want to make coffee at the same time.
* This post was edited 10/30/09 05:45am by TomG2 *
PackerBacker
Home is Montreal Qc & Seasonal is NY Adirondacks
Posted: 10/30/09 05:39am Link  |  Quote  |  Print  |  Notify Moderator
No, I could not run the 13.5k btu air conditioner in our 5th wheel with my Honda 2000.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
My Photos
shadoow
South Texas
Posted: 10/30/09 06:05am Link  |  Quote  |  Print  |  Notify Moderator
my case would be one of the ones that didn't. Our trailer has the Dometic 13.5k AC.
2009 Cedar Creek 34sats
2007 Chev 3500HD D/A
1952 Wife
samsontdog
Sac. Ca summer, Yuma Az winter
Good Sam RV Club
Posted: 10/30/09 08:15am Link  |  Quote  |  Print  |  Notify Moderator
Will not run my 13,5K A/C
samsontdog
pianotuna
Regina, SK, Canada
Good Sam RV Club
Posted: 10/30/09 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Hi ttyuille,
Get a Kill-o-watt meter and measure what the air conditioner draws while running. Double the measured "run" wattage to get the surge value, and compare that to the surge value on the Honda 2000. If surge is low enough then the Honda will run your air conditioner.
I chose a different route designed a system to allow me to run my air conditioner from an inverter. That means I can use as small as a 1000 watt generator if I so wished. For details, surf here:
Technology
and click on "Solar boondocking".
Regards, Don
Kustom Koach Class C 28'5" 256 watts solar, 875 amp hours in two battery banks 12 volt batteries 2500 watt inverter.
