RV.Net Open Roads Forum: Beginning RVing: Question About Winter Use of RV
 > Question About Winter Use of RV
Beginning RVing Related Tips
bigandhuge
Abilene, Texas
Posted: 10/30/09 10:13am Link  |  Quote  |  Print  |  Notify Moderator
I live in a part of Texas that frequently experiences freezing weather beginning about mid-November. In years past I have winterized by my toyhauler about this time of year and kept it in storage until March. This year I plan on using the toyhauler several times for hunting etc. over the next couple of months and am not sure if I should plan on winterizing the unit when I return from each trip or if it is ok to just drain the tanks and water heater. A friend in my area says he has never winterized his trailer and never had any problems, which makes me wonder if winterizing is overkill. I know lots of folks use the units during the winter months and am wondering how this situation is typically addressed. Any advice would be appreciated.
BigRigRVing
formerly CA
Posted: 10/30/09 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Depends on how low temps get and for how long, but I would just blow the water lines out, drain tanks, and p traps.
Gary & Cheryl and our chocolate lab named Caddy
2005 Newmar Mountain Aire 4304 w/ Blue-Ox Sports Lift
2006 Jeep Rubicon
HD 2006 Softtail Deluxe
www.BigRigRVing.com
skipnchar
Topeka Kansas USA
Posted: 10/30/09 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Water freezes when it reaches 32 degrees regardless of what part of the country it's in. In your area you could probably get along just fine leaving water IN the tanks and turning on a little heat in the RV when it's predicted to get cold over night. If it's a four season RV (doesn't sound like it is) you may not need to do anything but if it's NOT then it'll probably leak enough heat outside to warm the surrounding area by a few degrees.
On the other hand it takes only about 10 minutes to blow out your water lines once you have the right equipment.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
bigandhuge
Abilene, Texas
Posted: 10/30/09 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the responses. A couple of follow up questions: Do you need to drain the water heater each time also? AS for the right equipment, I have a compressor and a fitting that goes over by city water connection. Anything else I need? Thanks again.
Rolling Condo
South Carolina
Posted: 10/30/09 11:23am Link  |  Quote  |  Print  |  Notify Moderator
I always drain and blow my lines including the water heater, put a cup of RV antifreeze down each drain to protect the P-traps for good measure. Make sure you regulate the air pressure to no more than 40 psi as to not damage the water line connections or fittings by over pressure. Make sure you blow all faucets inclding the toilet flush valve till you get only air coming out.
Note I do live in the south but we can and do have extended freezing temps that could damage plumbing should it not be protected in some manner. Never had any issues over the years following this method.
'90 GMC R2500 7.4L
'90 Avion 34V
Cummins Onan P4300ie
Reese Dual Cam HP
Prodigy
Luke Porter
Not on the road :(
Posted: 10/30/09 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Takes about $4.50 of anti-freeze to winterize my 38' rig.
States I have spent the night in my current rig, bought three years ago.
Have RV'ed through 49 states and been in all 50, just short of my half-century.
bigeking
Arlington, Texas
Good Sam RV Club
Posted: 10/30/09 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have been told by a dealer in Tyler and one in the DFW area, that all they do to the units on their lots is drain all water from the units.
Everett & Jayne
2008 GMC Duramax-Allison Extended Cab Dually Locking 3:73 rear end
Line-x bedliner Pullrite hitch Retrax Bed Cover---2008 Nu Wa DA 339RSB
Life is'nt about how you survived the storm...
It's about how you dance in the rain!
Bobbo
Memphis, TN
Good Sam RV Club
Posted: 10/31/09 08:21am Link  |  Quote  |  Print  |  Notify Moderator
I have winterized. We are taking the MH out in about a week, so I will un-winterize, then winterize again when we get back. The RV club is having a camp out 2 weeks after that so I will un-winterize, then winterize again when we get back. In December, we are taking a Christmas trip so I will un-winterize, then winterize again when we get back.
It only takes about $4.00 worth of RV antifreeze and 30 minutes to winterize and it is worth it for my peace of mind.
Bobbo, Linda and the furry kids (German Shepherd and German Shepherd mix)
2007 Winnebago Outlook WF331C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
Oldtymeflyr
Littleton, CO
Posted: 11/02/09 06:31am Link  |  Quote  |  Print  |  Notify Moderator
It gets cold in the panhandle of Texas, long enough to do damage to an RV filled with water.
With a compressor and half a gallon of RV ant freeze you are in business.
Drain the water heater! I do not use a bypass because we now drain and use a compressor, we do not use the fill the supply system with RV antifreeze any more so we do not need a WH bypass. We only use the RV antifreeze for the drains.
People say about 30 minutes and I think thats a pretty good number.
palmbeachrv1
West Palm Beach Florida
Posted: 11/03/09 09:31am Link  |  Quote  |  Print  |  Notify Moderator
I agree with most everyone. Be sure to drain your water lines, tanks and anything with water in it and you should be fine.
Keystone RV is the #1 selling RV in the nation. Palm Beach RV is the Largest Towable Keystone RV Dealer in Florida. Visit our site to see why.http://palmbeachrv.com
