RV.Net Open Roads Forum: Help with replacing leaky hose on water heater
 > Help with replacing leaky hose on water heater
Travel Trailers Related Tips
tchart
midwest
Posted: 11/03/09 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2010 Rockwood and noticed that the water heater line has a slow leak. We are several miles from a dealer and would like to repair it ourselves. We were told by a repair shop to use a Pex fitting since the fitting is crimped on as an assembly from the factory and hard to get to. Does anyone have any experience in doing this. Any help would be greatly appreciated.
StoneyPgh
New Kensington, PA Steeler Country
Posted: 11/03/09 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Pex can also be repaired with Shark Bite fittings found at Lowe's and Home Depot. They do not require a crimper and work well in close quarters.
Peter & Nancy --- We never had a bad day camping
'03 Silverado 2500HD LS XC SB 4X4 8.1L/Ally 3.73
Reese Pro Series 15K Kwik Slide Prodigy Controller
'08 Trail Cruiser TC527RL Rear Lounge V-Series 5er
BobJoh
Whitestown, IN 46075
Posted: 11/03/09 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Get that rubberized tape roll at NAPA and wrap it and tape will merge/blend into a nice rubber wrap patch for a temp. repair.
BobJoh
tchart
midwest
Posted: 11/04/09 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone. Im going to work on it tonight.
Center Pin
Fort Langley, BC
Good Sam RV Club
Posted: 11/04/09 09:24am Link  |  Quote  |  Print  |  Notify Moderator
When working with PEX if you need to bend it or work in tight spaces warm it up a bit. I run hot water trough it for a minute, this greatly reduces the chance of it kinking.
Trailer: 07 Tango 299BHS
TV: 2004.5 Dodge 610 CTD 3500 QC 48RE 2wd Laramie SRW, FP Gauge, FASS 95/95, Rhino Lining, Hensley Arrow, Reese Signature Series 5er Hitch, Air Bags & Compressor, Canopy, AL Boat Rack.
Been running B100 home brew June 2008!
Sherush
Brampton, Ontario, Canada
Posted: 11/04/09 09:33am Link  |  Quote  |  Print  |  Notify Moderator
We just redid all the plumbing in our trailer and moved water pipes around (to make more sense and provide more storage space) and we used Shark Bite bought at Home Depot and made the job easy and leak proof.
redwake
Visalia, CA
Good Sam RV Club
Posted: 11/04/09 10:03am Link  |  Quote  |  Print  |  Notify Moderator
once upon a time i had a plumber friend he swore by these shark bites always had a bag of them in his service truck.
one of these days i'm going to go pick a bag up and keep it in the TT JIC.
TT: 08 Monterey 27 PT by Extreme RV
TV: 06 Sierra K1500 SLE Crew - 3.73:1 4x4 w/5.3L
Hitched with a Husky WD & SC.
Powered by Champion 3500
