RV.Net Open Roads Forum: Where is the fresh water tank overflow tube?
 > Where is the fresh water tank overflow tube?
General RVing Issues Related Tips
nelsonck1
East Troy, WI
Posted: 11/03/09 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Last year we purchased a Pilgrim Open Road fifth wheel. It has an enclosed underbelly. Recently, after filling the fresh water tank, we've noticed water dripping from around a tube sticking down through the enclosed area. From reading other postings, it seems as though the water might be coming from the tank overflow tube, but shouldn't this tube terminate somewhere outside of the enclosed area so that the water doesn't build up inside the enclosed area? We're wondering how/where to find the overflow tube so that we can determine if this is really the cause of the water drip. Would appreciate any suggestions.
JJBIRISH
Butler, PA, USA
Good Sam RV Club
Posted: 11/03/09 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
yes it should...
its not a over flow but a vent tube that is usually right near the fill cap
Love my mass produced, entry level, built by Lazy American Workers, Hornet
pinesman
virginia
Posted: 11/03/09 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
My overflow tube is right above the fill hole. I would think what you are seeing could be the tank drain. Maybe they did not cut a hole inthe fabric for the drain.
shum02
Burlington ON CDA
Posted: 11/03/09 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Is it dripping from the tube or around the tube? Could be condensation wicking down the drain tube, which is what that tube sticking through the belly is.
2007 F150 XLT CC 4x4 5.4L 3.73LS
2007 KZ2505QSS-F Outdoorsman
Camping Pic's and Mods
Winter Camping Tips and Tricks
aeohio
New Mexico
Good Sam RV Club
Posted: 11/03/09 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
I would agree its probably the drain tube for the tank. Look at it and see if it has a screw off cap or valve. Mine has a screw off cap. You may have a bad valve or crack in the cap.
The overflow tube is near the fill hole.
2010 Passport UL 290BH
2006 Ford Expedition Limited
Luke Porter
Not on the road :(
Posted: 11/03/09 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
I think my "overfill" tube is an overfill tube as it is surrounded by a piece of flat tubing the expands when water runs out.
Anyway, it's on the bottom of the rig on the aft end of the tank. The fill is probably 8' forward of the tank. So , they are 10-12' apart.
* This post was edited 11/04/09 06:12am by Luke Porter *
States I have spent the night in my current rig, bought three years ago.
Have RV'ed through 49 states and been in all 50, just short of my half-century.
JJBIRISH
Butler, PA, USA
Good Sam RV Club
Posted: 11/04/09 01:28am Link  |  Quote  |  Print  |  Notify Moderator
with most stand right in front of the fill tube while filling, I assure you, you will know when it full...
nelsonck1
East Troy, WI
Posted: 11/04/09 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the ideas. There is what I assume to be a vent tube right near the fill connection. We've never filled it to the point where water comes squirting out this tube.
The water that drips/runs out from the enclosed bottom comes from AROUND the tube, not from the tube itself. There's a lot more water there than what would develop from condensation. The tube I'm talking about is actually the fresh water tank drain tube - to completely drain the tank. There is a screw cap on this tube.
Additional suggestions/ideas are welcomed.
Deen
Vancouver, WA
Posted: 11/05/09 12:52am Link  |  Quote  |  Print  |  Notify Moderator
Yep, keeps the critters out but still lets the water out.
AGBAT
NM
Posted: 11/05/09 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you have a leak in a fitting up near the tank itself. Some small drips, especially ones that are not under a lot of pressure, will seal themselves over time. Minerals build up and seal the loose fitting. It may be worth removing the bottom protection and seeing if it is just a loose band clamp or a standard pipe fitting that is loose.
Chevy 2500 Duramax, 30ft Prowler, 18ft Bass Boat, 2 big dogs,
Boondocking at Rio Costilla, NM
