RV.Net Open Roads Forum: About to tow HHR for first time - How does yours tow
Search only in Dinghy Towing
 > About to tow HHR for first time - How does yours tow
Dinghy Towing Related Tips
Happy Jim
Owensboro KY
Posted: 11/04/09 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Well I get the HHR bracket installed - the diodes-the #8 fuse on off switch installed and now ready to take it out for a test run. I will be usimg a stowmaster tow bar that attached to the HHR.
Any thing I should know or watch out for. I went to the HHR from a Ford Escort
thanks
Travel Safe - Enjoy
Happy Jim
1999 Holiday Rambler Vacationer
2006 Chevy HHR Toad
gloriebkj
Lexington, TN USA
Posted: 11/04/09 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
We have been towing an HHR for about a year now with no problems. We really like it. The only complaint I have with it has nothing to do with the towing..it is that it made of tinfoil. I guess that helps with the weight. We have found that it scratches and gets little dings quite easily--still love it however. We have people ask about it at the campgrounds and see quite a few of them following MH's. We are using a Blue Ox system. I think you are going to like it also.
gloriebkj
Mrs. Locknload
Dixon, IL
Posted: 11/04/09 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
We've had our HHR for 3 years now. DH says it tows like a dream.
Mrs. Locknload, Locknload & Chewy
Dreaming of the day we become fulltimers.
Living the daily grind until then!
lanerd
Ridgecrest, CA
Good Sam RV Club
Posted: 11/04/09 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
You know, I think it is pretty much redundant concerning the type of toad to be pulled. If they have all the necessary towing equipment (base plate, tow bar, lights, brakes) and is weight matched to the MH, I bet just about any and all toads will pull very well indeed. Especially with a DP as the MH, most toads can't even be felt by the driver, hence the need for a camera/monitor to insure it's still back there.
I love the looks of an HHR and have considered having one for a toad. Don't know about their reliability, but I have read that Consumer's Report gives them a pretty bad rating.
Tow that HHR and enjoy.
Ron & Sandie
'08 Safari Simba SBD35
Toad: Restored 86 Toy 4x4 P/U
Tow Bar: Sterling
Brakes: Unified
TPMS: Pressure Pro
RETIRED!! How sweet it is....
Delaine and Lindy
Linden Tn. (The View) /Gulf Shores, Ala.
Posted: 11/04/09 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
I never read Consumer Report! We had a 2007 Chevy HHR never had a problem at all. We just bought a 2009 Chevy HHR and are towing it behind the Mobile Suites. Yes its set up to tow, base plate, tow bar, lights and braking system. As said don't really know its back there. We do have a hard wired rear Camera and keep a eye on it when rolling. The HHR is so simple to prepare it to two. Just remove the # 8 fuse put it in netural and turn the key to on and away you go. We did a lot of research and the Chevy HHR was heads above on the Pro's and Cons. Weight was a factor in our decision and it had to be towable four down. It works great for. GM makes several cars that are towable. There are many small cars that are towable, but we had to have room for our furr kid "Montana" and most small cars didn't have the room in the rear. Good Luck on your decision. GBY....
2006 FreightLiner M2
Trailer Saver Air Ride (TSLB2H)
Pressure Pro System
2008 Chevy Silverado 1500 C/C (Grocery hauler)
2009 Chevy HHR LT 2
2010 Mobile Suites 38 RSSB 3/4
www.webspawner.com/users/lnhdch
We are BLESSED!!!!
SPRING STREET
LOUISVILLE KY.
Posted: 11/04/09 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Just finished a 1000 mi. trip towing my hhr and towed great. the only problem I found was it is heavier than my previous towed ,a VW, and I borrowed a BrakeBuddy to assist in braking.Had problems getting the sensitivity correct and it would set off the BB at strange times and circumstances.. Not the HHR's problem just thought I would mention it.. Also it does sit low to the ground and does pick up road rash..
2000 37 1/2' MOUNTAIN AIRE BY NEWMAR,TOAD 2009 HHR, License plate "TOWED" > RoadMaster Tow Bar and Base Plates.
mscamping
any place, USA
Good Sam RV Club
Posted: 11/05/09 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Hi, we got ours the last of May and love it so far.. Great milage(2.2 engine), gas tank is alittle small, seems like I'm aways at the gas station filling up, but it will due for now.. Don't even know it's back there when towing.. Ours weighs 3250# full of gas and no people.. Hope it's as good to us as the '05 Malibu Maxx was.. Would have gotten another one of those, but they quit making them.. Since this is our only vehicle, we trade about every 4 to 5 years..'05 Malibu had 50,000 driven miles and another 29,000 towed miles..Good luck with yours..
Mike..
2003 Holiday Rambler Neptune 36 PBD 38' - ISB 300 Cummins w/Allison MH2000 5 speed
2009 HHR w/Blue Ox Aventa II & SMI Stay-n-Play Duo
FMCA - HRRVC - Chapters - 56,57,& 419 - Good Sam Life Member - Coach Net - 3/4 timers
Mike & Sharon
mscamping
any place, USA
Good Sam RV Club
Posted: 11/05/09 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Jim, what did you come up with to put the #8 fuse on a switch?? I have been thinking about doing that, but wasn't sure how or what to do so it didn't cause problems..Thanks..
Mike..
Happy Jim
Owensboro KY
Posted: 11/06/09 10:10am Link  |  Quote  |  Print  |  Notify Moderator
MSCAMPING
I hope this makes sense. Pulled #8 fuse out. I took a wire and went from one leg of the fuse panel to one leg of the hanging fuse from the other leg of the hanging fuse to one leg of a on off switch from the othert leg of the on off switch to the remaing leg of the fuse box. I used crimp on connecters to the wires. For the one that goes in the fuse legs I took a connector that is used for a screw and cut on leg off so it would go in one leg the fuse box.
I drilled a small hole on the kick panel that covers the fuse panel and installed the on offswitch there. I got my on off switch from radio shack. The fuse is 2 amps
Cody47 did the same thing in a little differant way on this forumn also. My way no need to cut the leg on the fuse ect.
Send me an e mail and I will give you a call if you wish
good luck
Jim
mscamping
any place, USA
Good Sam RV Club
Posted: 11/06/09 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Jim, I think I got it.. You just make a harness with a fuse in it and a switch on one end that you mounted on the outside panel and put the other ends into the fuse panel.. Sounds good..
Mike..
