RV.Net Open Roads Forum: Tech Issues: headlights
 > headlights
Tech Issues Related Tips
bigrig1944
Liberty,SC
Good Sam RV Club
Posted: 11/04/09 08:55am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2003 Fleetwood Flair. The headlights are on when the switch is on, my question is there anything I can do to keep the lights off where I have control of headlights by using my light switch. Any help please.
Darryl&Rita
Grande Prairie, Alberta
Posted: 11/04/09 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Old 78 SRW F350 w/460 54 miles pulling a new(to us)98 28 foot citation 5'er
Krusty
Calgary, Alberta,Canada
Posted: 11/04/09 09:06am Link  |  Quote  |  Print  |  Notify Moderator
You may have some sort of daytime running lamp module installed. Find it and disconnect it. May help if you mention what type of chassis you have.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
bigrig1944
Liberty,SC
Good Sam RV Club
Posted: 11/04/09 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Krusty for the info. Its a Ford chassic
robatthelake
Vancouver Island
Posted: 11/04/09 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Not sure it is legal to disconnect Day Time Running Lights! They are controlled by a small Relay usually located under the Hood or Dash.
Rob & Jean
Dutch Star Diesel Pusher ..Tracker 4X2
kaydeejay
SE Michigan, USA
Posted: 11/04/09 09:45am Link  |  Quote  |  Print  |  Notify Moderator
They are called "Daytime running lights" or "DRLs". They should be at a reduced brightness from full-on lights. Many studies suggest they improve vehicle visibility in low-light situations and are a legal requirement in many countries (including Sweden and Canada).
Why do you want to turn them off?
Keith J, Retired from GM Engineering
1999 Sunnybrook 27RKFS Fiver
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin box, Multi-vex mirrors, TST TPMS.
Center Pin
Fort Langley, BC
Good Sam RV Club
Posted: 11/04/09 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Most DRL's do not come on until the parking brake is released.
Trailer: 07 Tango 299BHS
TV: 2004.5 Dodge 610 CTD 3500 QC 48RE 2wd Laramie SRW, FP Gauge, FASS 95/95, Rhino Lining, Hensley Arrow, Reese Signature Series 5er Hitch, Air Bags & Compressor, Canopy, AL Boat Rack.
Been running B100 home brew June 2008!
Wherever I happen to park
Posted: 11/04/09 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Well. the reason the headlights come on (often at reduced power) when the ignition is on is called Daytime Running Lights.
Several studies have been done which prove, beyond a doubt that running with lights on is way safer than without. So My advice is to leave excellent alone and don't turn them off.
I have read all the arguments against DRL's and so have the enginneers at GM
I (and they) remain convinced that is is way safer to run lights ON for safety!
kaydeejay
SE Michigan, USA
Posted: 11/04/09 11:48am Link  |  Quote  |  Print  |  Notify Moderator
Can you quote the statute to support that?
I recall, when GM made them standard in the mid 90s the dealers were authorized to disconnect them if customers complained.
Not sure if that's true anymore.
Also to legality, they fall into a strange category. They are not required by law (in the US) but if the vehicle IS so equipped, then there are standards they are required to meet!
(Which, to keep life simple as always, are DIFFERENT from the Canadian requirements!)
But I strongly doubt anyone is going to get a ticket for diconnecting them!
bigrig1944
Liberty,SC
Good Sam RV Club
Posted: 11/04/09 11:50am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the input. I like the idea of running my headlights in the daytime but I want control over them. If I pull into a rest area or RV park and want to run my engine I don't want the lights on and bother anyone. I understand its a safety feature but I drove a truck for 40 yrs. and I had no probably running the lights in the daytime for safety. Thanks again for all the advice and info.
 > headlights
