RV.Net Open Roads Forum: Tech Issues: Changing tire sizes ???
 > Changing tire sizes ???
Tech Issues Related Tips
sunline1
Northeastern Pa
Posted: 11/05/09 06:22am Link  |  Quote  |  Print  |  Notify Moderator
My 97 chev 3/4T, 454 cu in, auto, 4X4, pickup has LT 245 75r 16 tires on it factory sized.
I have a chance to buy 4 good used LT 235 "85"r 16 tires.
Question is with the 3:73 rear axle ratio, wondering what effect if any the larger diameter tires will have on pulling my 7,000 lb camper ?
Any thoughts ??
Thanks
Sunline1
tvman44
Southwest Louisiana
Posted: 11/05/09 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Effectively increase your gear ratio a little.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
StoneyPgh
New Kensington, PA Steeler Country
Posted: 11/05/09 07:06am Link  |  Quote  |  Print  |  Notify Moderator
The change will be an increase in tire diameter of 32 mm, not enough to make any difference. Just make sure you don't lose any load rating.
Peter & Nancy --- We never had a bad day camping
'03 Silverado 2500HD LS XC SB 4X4 8.1L/Ally 3.73
Reese Pro Series 15K Kwik Slide Prodigy Controller
'08 Trail Cruiser TC527RL Rear Lounge V-Series 5er
skipnchar
Topeka Kansas USA
Posted: 11/05/09 07:57am Link  |  Quote  |  Print  |  Notify Moderator
6 tire rpm per mile difference and less than 1% error in speedometer.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
sunline1
Northeastern Pa
Posted: 11/05/09 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all sounds good.
Happy Camping !!!
Sunline1
Peg Leg
Anderson, IN
Good Sam RV Club
Posted: 11/05/09 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Sunline1, I went to the 19.5" and I tow about the same trailer. My tires made my speedo read about 10% under speed. Mine still pulls great, it likes to run a bit faster in OD with the cruise on to keep from unlocking the converter. I just use the pedal more and can keep it locked at my desired speed.
KA9ATV
K2500 7.4 3.73
Michelin 245/70R19.5 XDS2 on Vision Type 81's
31' Dutchmen
Yamaha EF3000iSE
retired gadgetman
ejforwood
Littleton (Denver) Colorado
Good Sam RV Club
Posted: 11/05/09 10:38am Link  |  Quote  |  Print  |  Notify Moderator
You should check date code to see how old the tires are. JMHO!
* This post was edited 11/06/09 06:45am by ejforwood *
Jerry, Dottie & Chan, "the little furry one"
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
Deen
Vancouver, WA
Posted: 11/06/09 12:54am Link  |  Quote  |  Print  |  Notify Moderator
Any thoughts ??
Thanks
Sunline1
It's not so much the pulling the camper, it's the weight rating of the tire. Most good tires shops refuse to put lesser rated tires on. I was told it's the law but ....
sunline1
Northeastern Pa
Posted: 11/06/09 06:20am Link  |  Quote  |  Print  |  Notify Moderator
Deen
These used tires are from a relative, and they are load range E as are my current tires. Load range E came on the truck when it came from the factory, as I ordered it.
Sunline1
