RV.Net Open Roads Forum: Tech Issues: Generator ground rod
 > Generator ground rod
Page of 6
Tech Issues Related Tips
larry cad
Whatever.....
Posted: 11/07/09 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Salvo wrote:
Please list the failures where it's better to have a bond (in RV). I know of none.
Sal
The system bonding jumper is a conductor, screw, or strap that bonds the metal parts of an SDS to the system neutral point. The system bonding jumper provides a low-impedance fault current path to the power supply to facilitate the clearing of a ground fault by opening the circuit overcurrent device.
During a ground fault, metal parts of electrical equipment, metal piping, and structural steel will become energized. This situation provides the potential for electric shock and fire. The system bonding jumper resolves this situation by creating a path from the metal parts back to the source and allows overcurrent devices to operate, thereby removing the dangerous condition.
Salvo, this is certainly the one I would be most concerned about.
Salvo
California
Posted: 11/07/09 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
larry cad wrote:
Sal
Bonding is one of the factors that caused the sparks to fly, destruction of equipment, death, possibility of fire, etc. Yes, fuses or breakers can blow, but not before the above mentioned can happen. 15A needs to flow before the fuse blows. What if it's not a hard short, but only 10A flow? The breaker will not trip. Something will get awful hot.
This scenario will not happen in an unbonded system. Not with one fault. There are no equipment loss, deaths, fire or what ever.
Sal
Broccoli1
Los Angeles
Posted: 11/07/09 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
Salvo wrote:
larry cad wrote:
Sal
Sal
Sal-
What is a soft short?
06 F250 V10 SB 4x4 Gulp Gulp
WW FSC2800
Rhino 660- 1980 Cobalt 18DV
Power Wheels 750
"Shoot, I'm the world's best backwards driver!"
Salvo
California
Posted: 11/08/09 11:14am Link  |  Quote  |  Print  |  Notify Moderator
What if you got a rusty nail that's shorting the hot cable to chassis. Due to the nail's oxidation, the shorting resistance may be in the order of 12 ohms. It's not a hard short as it won't trigger the 15A breaker.
Sal
ol Bombero-JC
Posted: 11/08/09 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Holy Mackel Andy !!
In the second post old guy was pulling "our" chain/s . . . .
then the "pros" entered the discussion hosting each others petards . . . .
and the "average Joe" is scratching his dandruff while mumbling, Huh??
Ya'all need to step in front of a mirror and pat yourselves on the back,
and say, "Well done, self!"
Not only that - it was accomplished in "only" six pages!
Page of 6
