RV.Net Open Roads Forum: Survey: New Rear Coil Spring 1/2 T Ram Owners: Towing
Search only in Tow Vehicles
 > Survey: New Rear Coil Spring 1/2 T Ram Owners: Towing
Tow Vehicles Related Tips
eightballsidepocket
San Jose, California, USA
Posted: 11/08/09 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Just got my curiosity; there's got to be some 09 1/2 ton Ram owners out there that are towing.
What are your opinions about the rear coil springs versus the previous leaf sprung rear ends on the earlier 1/2 ton Rams?
How the the quality of the ride when unloaded?
Regards, Eightballsidepocket
2005 Dodge Ram 2500 SLT 4x2 Quad Cab, Cummins, 48RE Tranny, Lg Bed, Line-X Spray-on Bed Liner.
06 T25BS Komfort Trailblazer TT
"If you can't say it in person, it isn't worth saying while hiding behind an anonymous P.C.!"
surveyorjp
Missouri
Posted: 11/08/09 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
I'm curious as well. I've gotta think about the future (like 5 years from now) when I replace this old Ram. A 1/2 ton is all I need, but towing with those coil springs has me curious. I really like a stiff rear suspension when towing, that's why I installed Timbrens on this truck. I might have to go to a 3/4 ton, or go with an 08 or older Ram 1500. But man, that new sheetmetal is so much nicer!!
Their is a fellow on here with a black 09 Hemi Ram 1500 crew cab with a sleek new TT. I'm hoping he catches this thread.
2005 Surveyor SV-291
1995 Dodge Ram 1500 Laramie SLT 4x4 5.9L V8
cougar88nw
Prescott Valley, AZ
Good Sam RV Club
Posted: 11/08/09 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
Coil Springs are for cars.....not the rear suspension of a truck. IMHO
http://www.youtube.com/watch?v=QxGlJ1mjIAw
Pilot---Mark , Co Pilot (boss)Nancy
Children:
Alyssa , Corey , Matthew, Kaylyn
Dogs: Shih-Tzu's(other children)
Max , Shelby, Twiggles
TT 2001 Sunnybrook 2708 SLE
TV 2004 Ford Super Duty F-250 Diesel 6.0
Yamaha EF3000iSE/Honda EU2000i
surveyorjp
Missouri
Posted: 11/08/09 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
That's a nice Ford commercial you got there. Not exactly what the OP was asking for though. He wants real world experience, not some paid for by Ford fellow trying to discount Dodge's approach with his scripted blather and opinionated nonsense. Most all unbiased sources are give the Dodge 1/2 ton suspension very high praise for its stability and ride comfort when empty, and when carrying some weight.
loufish
Burbank, CA
Posted: 11/08/09 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
Really?....The front end of many 3/4 - 1 ton trucks use coil springs...even with the heavy weight of diesel engines...
I haven't kept up with what Dodge is actually doing with their new 1/2 model, but I know in the pre-release info it would be only tow rated for about 6500 lbs, they even stated there would be no real tow package(HD cooling, tow mirrors, etc...)Dodge's thinking at that time was if you needed to tow more then get the next size up truck...
"I won't camp next to you, if you don't camp next to me!"
2004 Titan King Cab, 2wd, 5.6L V-8, 5 Speed Auto Trans
Tow Package with killer 3.73 tow gears and TruTrac.
2002 Honda XR650R
surveyorjp
Missouri
Posted: 11/08/09 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Dodge, by their own admission, was VERY conservative on the 09 Ram 1500 models in regards to towing capacity. The 2010 1500 models have increased the towing capacity to over 10,000 lbs when properly equipped, without any actual modifications or changes made between 09 and 2010.
loufish
Burbank, CA
Posted: 11/09/09 06:20am Link  |  Quote  |  Print  |  Notify Moderator
Ok, they did make changes before finally releasing the 10' model...
Thanks..
windellmc
Indianapolis
Posted: 11/09/09 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Just from test drives with no trailer I would say ride comfort is comparable to the Ford but the Dodge feels more stable. If you like a stiff rear suspension, air bags for the Dodge cost less than $100 since they are just stuffed into the middle of the coil springs. Edmunds claimed it towed more confidently than the other 1/2 tons. That is probably due to the additional lateral stability you get from using a linkage to control side to side movement rather than relying on the stiffness of a leaf spring.
SoCalDesertRider
SanDiego, CA, USA
Posted: 11/09/09 09:50am Link  |  Quote  |  Print  |  Notify Moderator
I prefer leaf springs, but with a thicker sway bar, stiffer polyurethane sway bar and 5-link bushings and stiffer coil springs, it would probly make an ok tow vehicle.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
eightballsidepocket
Posted: 11/09/09 10:06am Link  |  Quote  |  Print  |  Notify Moderator
I'm still hoping for some 2009 1/2 ton Dodge Ram owners to chime in here.
I would genuinely like to read/hear about their experiences with the new Ram, and it's revised rear suspension when carring payloads, towing, and also driving empty?
So far the posts have basically been about, liking or disliking rear coil suspension. These are not the posts that answer my original post.
There's got to be some forum member here that have purchased a new 1/2 ton Ram?
