RV.Net Open Roads Forum: Travel Trailers: Found that sucker!
 > Found that sucker!
Travel Trailers Related Tips
Rosehill
Central West Texas
Posted: 11/08/09 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have been fighting a persistent roof leak for quite some time. Not only persistent, but also well hidden. I was SURE it was the air conditioner, but after installing a new gasket, the leak was still there. During heavy rains, I would have water dripping out of the overhead light in the bathroom. I tried pressurizing the tt with no luck, I couldn't get any bubbles.
Going on the assumption that water runs downhill, it was logical that the leak had to be above, or on the same level with the light. So I decided that what was needed was air pressure in the space between the ceiling and the roof of the tt. After scratching my head, here's what I did.
I removed the bathroom light from the ceiling and drilled a small hole just the right size to wedge the nozzle from my small shop vac into. I then unscrewed and lowered all the other lights in the tt, and used duct tape to seal the holes where the wires came out. I also removed the air conditioning cover and used duct tape to seal the hole where the wiring came out, and around the edges where air could escape.
I then fired up the shopvac and slathered the roof with soapy water. Every seam and penetration. AND THERE IT WAS. It was leaking around the vent cap for the black tank vent.
I removed the old caulking and unscrewed the ventcap. And it was confirmed that this was my leak. There was water under the base of the ventcap and the insulation was damp from my soapy water. It's now sealed off nice and tight. Another leak defeated.
I also used this same method (since I already had the hole), to check all my cleareance lights as well. Found one blowing bubbles, it's fixed as well.
Just another idea to try if you have a roof leak that refuses to be located.
The old tt is dry once again........until something else starts leaking.
Me and DS
Velcro and Minnie the felines, a bunch of Borzoi
1992 Dodge B350 "The Dawg Van"
1987 Kit Road Ranger Model 199 "The Dawg Haus"
"It's not old, it's vintage!"
downtheroad
Puget Sound
Posted: 11/08/09 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
There you go....smarter than the average leak.
Nice job...
"If we couldn't laugh we would all go insane"
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Picture
Reese Dual Cam HP
Lots of other stuff nobody cares about
wthibeaux
DeKalb, TX
Very smart! Great post.
Warren & Peggy
Four cats "Albert, Noble, Peaches, Lil Bit" all neutered.
99 Chev Suburban 1500 5.7L 3.73 2005 Chev 1500 Crew Cab 5.3L 3.73
95 Mobile Scout 25FS travel trailer
5 grandchildren
btd35
Spokane, WA
Posted: 11/08/09 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for sharing that! I'm sure down the road I may need that information. Great idea, and congratulations!
Tom & Beth
05,Grand Junction 35TMS
99, Dodge 3500 Dually.
sdavis622
Puyallup, WA
Posted: 11/08/09 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Sweet, good find!
*Shane & Jen
*DD-Miley Nicole-Born 9/24/2009
*2 Dogs-Tank & Abbey
-2007 Ram 2500 Laramie QC SB 5.9l Cummins
-2006 Arctic Fox 25S
Trailer Mods! Trailer! Truck!
camping man
Central Fla.
Posted: 11/09/09 07:01am Link  |  Quote  |  Print  |  Notify Moderator
I pressurized my RV with my leaf blower to find the leaking screw on my awning track.
05 Dodge 2500 2WD Quadcab,6cyl. Diesel
Me
smkettner
Good Sam RV Club
Posted: 11/09/09 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Just curious now with hindsight, could the leak have been found with a closer visual inspection? Was the caulk perfect and just not atttached to the vent?
Great work BTW
sonicsix
Jemison, AL
Good Sam RV Club
Posted: 11/09/09 09:48am Link  |  Quote  |  Print  |  Notify Moderator
LOL, I was expecting this to be a mouse thread. But good job of finding that leak.
Why We RV | Our Lighthearted Blog | Our Big List of Mods | The RVer's Library
Rosehill
Central West Texas
Posted: 11/09/09 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Wish it had been a mouse, might have been easier to find. Or to just install a cat.
Rosehill
Central West Texas
Great work BTW
Even with hindsight, I would not have found it. I had done a very close visual inspection (more than once) and never found this leak. The caulk was attached to the vent cover, and even when I poked at it, appeared to be well attached to the roof. But when I found the leak and got after it with a putty knife, I found water under the base of the vent cap. What appears to have happened was that the water was running from the top of the cap down the side, and around the little leg that holds the cap on (mine is a plastic two part cover....a ring that goes around the bottom and a top that has three little plastic legs that screw down. Basically, the leak was behind one of those little plastic legs, where no human could have seen it. Hidden or not, it blew bubbles, otherwise I would probably still be hunting it.
