RV.Net Open Roads Forum: Fifth-Wheels: Bleach smell in tanks
 > Bleach smell in tanks
Fifth-Wheels Related Tips
BC. CANUCK
CANADA
Posted: 11/08/09 11:15pm Link  |  Quote  |  Print  |  Notify Moderator
We bought a new Jayco 35RLTS and I thought I would disinfect the fresh water tank and lines. We have used the unit for two weeks and are still getting quite a smell and bleach taste from our taps. Any suggestions to get rid of it?
2008 FORD F350 P/S DIESEL SRW
2010 JAYCO 35RLTS DESIGNER2003 HONDA ST/A 1300
1999 CAMARO SS CONVERTIBLE
Golden_HVAC
Fulltime, CA, USA
Posted: 11/08/09 11:48pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
There is a saying that I heard once, the Solution to Pollution is Dilution.
So if you have 15 PPM free chlorine in the water, then adding another few gallons of water will bring down that super high concentration. I would fill the tank, drain the water heater, and then run some water through the pump out the water heater drain, then re-insert the plug. Fill the tank, and run some into each fauscet. Fill the tank to almost the top, then take the RV for a drive. This will slosh the water around, and help clean any chlorine from the tank.
Drain and repeat until the water does not smell. Then it will be ready to use.
You might have to dissolve a tablespoon of baking soda in a cup of water, add that to the water fill hose, then add that to the fresh water tank. This might help get rid of some of the smell.
Next time mix up a tablespoon of Clorox. This is about 5% chlorine, and that is 50,000 PPM. Mixed with 10,000 tablespoons of water, then you will get 5 PPM free chlorine in the water tank, plenty to sanitize the tank.
There is 3 tablespoons in a ounce of water, and 132 ounces per gallon. So 8 gallons is about 1,000 tablespoons. 1 tablespoon is enough to treat up to 80 gallons!
Mix the tablespoon of clorox in a cup of water, and then pour this into a drinking water hose, and fill the water tank. Really easy.
Good Luck,
Fred.
old guy
Oregon (pronounced Or e gun)
Posted: 11/09/09 12:00am Link  |  Quote  |  Print  |  Notify Moderator
just run a ton of water through the tank and lines and next time don't use such a strong solution of bleach to disinfect the system.
2oldman
Indio CA
Posted: 11/09/09 12:19am Link  |  Quote  |  Print  |  Notify Moderator
Lemon juice.
Pipeman
Windsor, Ontario, Canada
Good Sam RV Club
Posted: 11/09/09 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Just wondering if you have an in line water filter with the cartridge. If you do maybe change the cartridge. If not, then lots of fresh water through the tank and lines. Good luck.
Pipeman
Ontario, Canada
35 year Fire Fighter(retired)
VE3PJF
squeakkos
parker az
Posted: 11/09/09 06:24am Link  |  Quote  |  Print  |  Notify Moderator
time & lots of water also there was a addative called seetwater that added to your tank to make the water taste better that was years ago.
texasbaskets
Frisco, TX
Good Sam RV Club
Posted: 11/09/09 06:57am Link  |  Quote  |  Print  |  Notify Moderator
There's really very little water in the lines themselves, it's probably residual in the tanks.
As said about all you can do is dilute it. Fill and drain the tanks (heater too) until the smell goes away, then fill and run water through the lines.
Cheers !!!
Michael, Kay, and Prissy (The vicious Malti-Poo)
'05 Coachmen SportsCoach SE 372DS a.k.a. "Mana's Cabana"
skipnchar
Topeka Kansas USA
Posted: 11/09/09 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Open the derain valve for the water tank and take the trailer for a drive on a curvy road with lots of starts and stops. After about a half hour your tank should be very CLOSE to completely empty and you can then flush it out effectively. OK mod you can delete this now
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
Mile High
Lone Tree, CO
Posted: 11/09/09 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I gave it a guess once and mixed the bleach too strong - and for days it would whiten your teeth! It took several weeks to get back to normal. I did hear the baking soda can help.
Brad & Dory
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2007 Montana 3400RL 5th Wheel Our Rig - Our Mods
Visit Us, Our previous rig - 2003 2955RL
rlreed
Ohio
Posted: 11/09/09 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Add a little vinegar to the water then rinse....
