RV.Net Open Roads Forum: Tech Issues: Will my Garmin work in Canada
 > Will my Garmin work in Canada
Tech Issues Related Tips
jwill5046@aol
Yuma, AZ. 85367
Good Sam RV Club
Posted: 11/09/09 07:06am Link  |  Quote  |  Print  |  Notify Moderator
I have a Garmin 2730 with the 2010 update. I am planning a trip to Alberta, Canada next summer. I am wondering how much I will be able to use my Garmin as is , will I have to add anything to get the coverage I need
427435
Rochester, Mn
Posted: 11/09/09 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Don't know about the Garmin but my 3 year old Lowrance worked fine.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
Dick_B
Palos Heights, IL USA
Good Sam RV Club
Posted: 11/09/09 07:26am Link  |  Quote  |  Print  |  Notify Moderator
If you are at the Garmin try routing to Alberta and see what happens. You could then search for `restaurants' near the destination or `fuel', etc. to see what coverage you have.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
JMTTS
52.1122 N, 106.5625 W
Good Sam RV Club
Posted: 11/09/09 07:41am Link  |  Quote  |  Print  |  Notify Moderator
No Problem- If you have the North America map installed (Which is the normal situation). My Garmin C530 and 265WT have guided me completely across Canada and as far south as the RGV.
J & M
2005 Cardinal 33TS LX with TrailAir
2004 Chevrolet Silverado 3500 4x4 DRW D/A (LLY) Crew Cab
jwill5046@aol
Yuma, AZ. 85367
Good Sam RV Club
Posted: 11/09/09 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the replies. JMTTS, I thought so but was not sure. Dick_B, thak you for the advice, Duh, guess I am not too bright this morning, I should have thought of that. Jerry
randallb
On the road
Posted: 11/09/09 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I went in to the language function of my Garmin and Canadian is not on the list. English, French, Spanish and German are choices but no Canadian. It should work in Quebec though.
Randy
Wherever I happen to park
Posted: 11/09/09 10:54am Link  |  Quote  |  Print  |  Notify Moderator
The GPS will work just fine... The problem is that most Garmin (And other company products) are actually two devices in one box... The GPS is one device, it will properly report your latitude, longitude and altitude for wherever it is most anywhere on the surface of earth or in the atmosphere (outer space it gets a bit iffy)
The problem is the mapping system..... May or may not know Canada.
Since I use a Garmin E-Trex (Very basic, no maps) and Microsoft S&T on the laptop via a tether cable.... Mine works great.. wherever I happen to be in North America (The map datum I have is N.A. I'm not sure what else is on the CD)
revrnd
Apsley, Ontario
Posted: 11/09/09 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
I've had several Garmins of the Etrex series & yes the basemap (at least in Canada) is brutal. Only the major highways & major bodies of water are shown. Even the outline of the lakes is approximate @ best. City Navigator North America is definately needed when using these units.
1986 Monte Carlo SS
2004 Chevrolet K2500HD (P3 controller, WD hitch T.B.D.)
2009 Rockwood 2106 Mini Lite
Retired GM of Canada Oshawa Truck Assembly Plant
Opened 1965 Closed 2009
PackerBacker
Home is Montreal Qc & Seasonal is NY Adirondacks
Posted: 11/09/09 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
My Garmin works throughout Canada and the US.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
My Photos
robatthelake
Vancouver Island
Posted: 11/09/09 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Randy
We Speak English OR French in Canada! Quebec is mostly French and the Rest of the country is Mostly English speaking!
Rob & Jean
Dutch Star Diesel Pusher ..Tracker 4X2
