I discovered a flat on my travel trailer that is parked in a permanent location. I have added additional blocks on each side of the axels for stability. Is there a way to safely change the flat without unblocking the trailer? My trailer is a 32' travel trailer. Any suggestions would be appreciated!
98bluewave wrote: I discovered a flat on my travel trailer that is parked in a permanent location. I have added additional blocks on each side of the axels for stability. Is there a way to safely change the flat without unblocking the trailer? My trailer is a 32' travel trailer. Any suggestions would be appreciated!
If it's in a permanent location, why are you worried about a flat?
2006 Nissan Titan CC with tow package added Timbrens
2006 KZ Frontier 2303P-F
Dual 6 volt GC batts
Equal-i-zer
Prodigy brake controller
Yamaha EF2600c Tri-Fuel Gen.
If you REALLY need to change/repair the tire I suggest you loosen the lug nuts, then jack up the axle under the spring plate close behind the tire. You should be able to get the wheel on and off without raising the trailer, especially if you have stabilizer blocks under it.
But, like the others, I'm curious - why bother, unless you are planning on moving the trailer at some point?
I had a Prowler permanently parked on blocks for 16 years and really didn't care WHAT the tires were like. I sold it in place so it was never a problem.
Keith J, Retired from GM Engineering
1999 Sunnybrook 27RKFS Fiver
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin box, Multi-vex mirrors, TST TPMS.
Thanks for providing an answer and not a question,kaydeejay! I'm not certain I will need to replace the tire in the next few months. However, I wanted to determine how to go about it if I should decide to change it. I had assumed I could do what you suggested but wanted another opinion. Thanks again!!
