Delaine and Lindy
Linden Tn. (The View) /Gulf Shores, Ala.
The BH 3670RL has to much pin weight for a 2500HD. I know you don't like hearing that you need a 1 ton Truck but it would be the best decision if your going with a BH 3670RL. Good Luck with your decision. GBY....
2006 FreightLiner M2
Trailer Saver Air Ride (TSLB2H)
Pressure Pro System
2008 Chevy Silverado 1500 C/C (Grocery hauler)
2009 Chevy HHR LT 2
2010 Mobile Suites 38 RSSB 3/4
www.webspawner.com/users/lnhdch
We are BLESSED!!!!
MrRepair
North East
1,ton dully at the very least. if not a MDT u
2010 Jayco Designer 35RLTS
2009 GMC 3500 Dully 4x4,CC,D/A
cooksvillewildcat
Cooksville, MD, USA
Take a look at the Open Range 385 RLS. It has a very similar layout (although I like personally like the 3670RL bathroom layout better - the Open Range 345 RLS has the same bathroom but a different living room layout.)
Both are much lighter (both in pin weight and in dry weight) than the Big Horn (Open Ranges are made to be pulled with a 3/4 ton truck - at least 1500 lbs lighter due to different slide mechanisms) .... take a look at them - they are comparable in quality and features to the Big Horn.
edited 11/10/09 09:20am by cooksvillewildcat *
Mark
'05 Chevy Silverado 3500 D/A CC LB
New Open Range Forum
'10 Open Range 399 BHS has arrived!
'05 Wildcat 29BHBP - Sold recently
Reese 18K Signature Hitch
Prodigy brake controller
jshul
Belmont, CA
Everyone here assumes that you are loading your trailer to its maximum...it seems that you have 4000 lbs. toplay with before you are a the max GVWR....none of these respondants suggest that you weigh the rig and TV before deciding if you are overloaded.
2002 Holiday Rambler Presidential 30'
2005 GMC 2500 Sierra Duramax/Allison
Crew Cab/Short bed/4x4
jetboat
texas
Saftey should be the most important item,the 2500 alone is not enough truck,plus the 4x4 reduces the tow amount.Get a 3500 series.
kakampers
Fulltimer
jshul wrote: Everyone here assumes that you are loading your trailer to its maximum...it seems that you have 4000 lbs. toplay with before you are a the max GVWR....none of these respondants suggest that you weigh the rig and TV before deciding if you are overloaded.
I can tell them from experience, even if they order NO options, the unit will weigh more than the brochure states. Ours came out of the factory with 2 A/C's and dual pane windows and weighed almost 13,000 lbs...DRY!!!
Unless they plan on putting nothing in it...common sense says they'll be very close or over on their weight ratings....JMHO.
Dianne and Tom
New Bern,NC
The Arctic Fox 33-5v that we now have is suppose to weight 10,500 but just after we got it I took it and weighted it and it was 11500 with very little on it. Last summer I went to a rally where it was weighted again this time loaded, it weighted 12,920 with a pin weight of 2800. The Arctic Fox or Northwood shows 1800. It looks like I can get a fiver with around 14,000 gross weight. Now what do I get? I want a good quality RV that will be towed across county and be used for extended periods of time.
2006 Chevy 2500 Duramax
2003 Artic Fox 33-5v
donn0128
Pronounced Ore-gun
Either get more truck or less fiver. It is a no brainer Tom. I am one of the BTDT crowd and can tell you from experience that any more fiver than you already have will be too much for the truck.
Donn
Dianne and Tom
New Bern,NC
Well the truck option is out. I like the truck and it did serve my needs. The DW is going to want a car soon. I just got so much money to spent!!lol The Heartland is out also. My next truck will be a one ton as when the wife gets a new car I am going to take her car. The new truck going to have to wait a couple of years. I need the government to give RVers a stimulus.
kakampers
Fulltimer
Dianne and Tom wrote: The Arctic Fox 33-5v that we now have is suppose to weight 10,500 but just after we got it I took it and weighted it and it was 11500 with very little on it. Last summer I went to a rally where it was weighted again this time loaded, it weighted 12,920 with a pin weight of 2800. The Arctic Fox or Northwood shows 1800. It looks like I can get a fiver with around 14,000 gross weight. Now what do I get? I want a good quality RV that will be towed across county and be used for extended periods of time.
Heartland makes several other models in the Bighorn line that have GVWR in the 14,000lb range...they are slightly shorter and there are some really great floor plans too...
Just checked, there are five Bighorns that will fit your towing capabilities. check here
