RV.Net Open Roads Forum: Tech Issues: Harbor Freight 45 Watt Solar Kit
 > Harbor Freight 45 Watt Solar Kit
Tech Issues Related Tips
fredandkathy
Johnstown, PA
Good Sam RV Club
Posted: 11/10/09 05:54am Link  |  Quote  |  Print  |  Notify Moderator
I got a coupon for a 45 watt solar kit from Harbor Freight for $150. The kit includes 3 panels, framework, a regulator and some lights. Can this panel be wired to charge both batteries in my motorhome while it is in my garage? I also thought about possibly charging my tractor battery which is 6 volts by coming off the regulator's 6 volt tap. Will this work?
toolman1
Cerritos, CA.
Posted: 11/10/09 07:31am Link  |  Quote  |  Print  |  Notify Moderator
fredandkathy wrote:
I got a coupon for a 45 watt solar kit from Harbor Freight Can this panel be wired to charge both batteries in my motorhome while it is in my garage?
If you intend to put the MoHo in the garage, solar won't charge at all!
A 120V trickle charger will be money better spent.
See ya out there!!
Hooliville member #128
Gary & Lynne.
'04 Dolphin 5320 WH-22
370W Solar
22' Mighty Mover Trailer,
60W. Solar.
Sand Sprite 4. 2.3L EFI sand buggy
'04 Polaris Predator
'84 Jeep CJ.
Golden Lab "Annie" for both of us
maddog348
Bakersfield,CA
Good Sam RV Club
Posted: 11/10/09 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Didn't say he was going to put the solar panels in the garage ~~ just the MH
hwybnb
Posted: 11/10/09 08:26am Link  |  Quote  |  Print  |  Notify Moderator
That is two or three times as much power as you need for a maintenance charger. A 15 or 20 amp panel would do the job if the batteries are charged up before putting it away. Aside from that it is my opinion that HF's solar panels are not very good. They use black amorphous cells which are less efficient and have a shorter life than the blue crystal types.
pulsar
Lewisville, NC
Good Sam RV Club
Posted: 11/10/09 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
beemerphile1
I'm only 54, I'm not a
Good Sam RV Club
Posted: 11/10/09 09:54am Link  |  Quote  |  Print  |  Notify Moderator
hwybnb wrote:
That is two or three times as much power as you need for a maintenance charger. A 15 or 20 amp panel would do the job...
I think hwybnb means watts, not amp.
Tim (in NE Ohio)
"Okay, I admit it, the only thing I'm really good at is being me."
2006 Weekend Warrior FK1900 towed by 1998 Ford E150 4.6L
2009 Aliner Sport towed by 2009 Pontiac Vibe 1.8L
1996 BMW R1100GS
2007 Trek 7.2FX
2005 Trek Madone 9spd.
hwybnb
Posted: 11/10/09 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Yup. Sorry.
2oldman
Indio CA
Posted: 11/10/09 10:11am Link  |  Quote  |  Print  |  Notify Moderator
I had no idea a solar regulator had a 6v tap.
mkirsch
Rochester, NY
Posted: 11/10/09 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
The Harbor Freight 45W solar kit has a 3V, 6V, 9V, and 12V output.
stevelv
Living on the island
Posted: 11/10/09 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Those panels are quite large for just 15W - I looked at them the other day when the regular price was $199 but didn't buy due to their physical size.
RV Park Finder
Ex Fulltimers
Repairing/Restoring 1984 Monaco Regent 36' Gas to restart RVing
DH,DW,Jake and Indie
