RV.Net Open Roads Forum: Class A Motorhomes: Key Issue - Question
 > Key Issue - Question
BIGDOMINO
Full Timing since July 13th 2007
Good Sam RV Club
Posted: 11/10/09 09:17am Link  |  Quote  |  Print  |  Notify Moderator
I lock the front door of the motorhome when we take off. Use the dead bolt. Whenever it rains a lot I have a hard time getting the key into the lock. When not raining it is good. what is causing this? Any suggestions to deal with it/
Thanks.
Steve__
Steve & Toni__
2008 38 foot Monaco Knight.
2001 Honda CRV in tow.
80 pound Golden named Max loving the ride.
FULL TIMING AS OF JULY 13, 2007
tandkj
Full timer
Posted: 11/10/09 09:21am Link  |  Quote  |  Print  |  Notify Moderator
I don't know about that issue but try spraying some lube into the keyhole before it rains next time to see if that helps. Good luck!
08 Camelot
07 Ranger Toad
One Golden Retriever at the Rainbow Bridge
FXSTOHIO
Ohio
Good Sam RV Club
Posted: 11/10/09 09:22am Link  |  Quote  |  Print  |  Notify Moderator
I would spray some lube in the lock and see if that helps.
2008 Pilgrim Lite 21LRB
2004 Chevy Silverado Extended Cab 4x4 5.3 Tow Pkg 3.73
Yamaha EF2400IS
ShapeShifter
Buffalo, NY
Posted: 11/10/09 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Most lubes that you can spray into the lock can attract dirt and cause more issues in the long run.
Go to a locksmith, or look in the locks area of a home store, and get a small tube of powdered graphite. It comes with a small nozzle you can insert in the lock, and puff in some of the graphite powder. Run the key in and out a few times and it will do wonders to free things up.
Graphite is the way to go, rather than something like WD-40, oil, silicone spray, or the like.
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
PJG061073
North Carolina
Posted: 11/10/09 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Hi, ran into the same problem... I lubed all the locks... Put key in partially and sprayed key ridge.... Inserted key in and out a few times. Issue resolved. I agree use graphite spray if possible
Have a wonderful day..
Regards,
M&P ..
2008 Safari Cheetah-40 SKQ
"CAN'T SHOW MY PICTURE, ..I'M IN THE WITNESS PROTECTION PROGRAM"..
CJTravler
Posted: 11/10/09 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for graphite. I use it on the RV and stick home locks regularly to keeps the locks from sticking.
Briteskys
Mesa, AZ
Posted: 11/10/09 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Copied from a locksmith site:
"Some lock manufactures actually strongly recommend against using graphite in the locks they make and tell people to use a teflon based lubrication. Medeco manufactures high security locks and uses what I think was a teflon-based lubricant (you can contact them at their website www.medeco.com to find out exactly what it is).
Always try to use what the manufacturer recommends to keep from decreasing the life of the lock and/or the finish"
'02 Beaver Patriot Thunder
Jeep Grand Cherokee
Ron & Jane's Travels
ShapeShifter
Buffalo, NY
Posted: 11/10/09 11:38am Link  |  Quote  |  Print  |  Notify Moderator
A dry teflon lube is also a good choice. I just don't think that any oil, silicone, solvent, or other liquid lubricant is a good idea. They may work in the short term, but may actually increase the gumming up of the lock over the long term.
