RV.Net Open Roads Forum: Full-time RVing: Skirt Teton 5th Wheel?
Search only in Full-time RVing
Open Roads Forum  >  Full-time RVing
 > Skirt Teton 5th Wheel?
Full-time RVing Related Tips
JakeInc.
Alpine, WY
Good Sam RV Club
Posted: 11/10/09 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Hello Winter Fulltimers!
For those of you with experience spending the winter in cold, snowy climates, here's a question. Do you believe it is necessary to skirt a Teton Homes 5th wheel trailer? We'll be staying at Bryce Canyon National Park for the next 5 to 6 months working as volunteers. The elevation is 7,900 feet with an average of 96" of snow in the winter and temperatures well below freezing.
The utilities in Teton Homes trailers are completely enclosed, heated and VERY WELL insulated. Do you believe it is really necessary to skirt such a trailer?
Thanks!
arizonadesertbrat
Where ever the pipeline leads
Posted: 11/10/09 10:03am Link  |  Quote  |  Print  |  Notify Moderator
We have a KZ Escalade and had the skirting made last year. I can not believe the difference in the 5er since we got it done. First off, it gives a little extra storage that is "out of the weather", next, the temp of the floor is a lot higher than without the skirting. Winds do not effect the trailer like they do without it. To answer your question, is it necessary? No, it is not. Is it worth the trouble and money? Yes, it is. I would do it again.
mpfireman
Cook County Il
Posted: 11/10/09 11:11am Link  |  Quote  |  Print  |  Notify Moderator
We were at Bryce Canyon this past March. The way that wind blows, along with the blowing snow, I would do anything to keep the RV warmer. And we did, we left for a warmer climate.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
Delaine and Lindy
Linden Tn. (The View) /Gulf Shores, Ala.
Posted: 11/10/09 11:12am Link  |  Quote  |  Print  |  Notify Moderator
I don't think if would be nessary, however I have never owned a Teton. They are for what I have read well built. But I wouldn't skirt my Mobile Suites, however I will never be in that kinda of cold weather as long as I'm able to move. It takes a certain type person to live in that type of climate. Make sure you have plenty of propane. And make sure you wrap the water lines with some type of heated tape. We have spent time in that area but it was in June, will never be there after August. Good luck. GBY....
2006 FreightLiner M2
Trailer Saver Air Ride (TSLB2H)
Pressure Pro System
2008 Chevy Silverado 1500 C/C (Grocery hauler)
2009 Chevy HHR LT 2
2010 Mobile Suites 38 RSSB 3/4
www.webspawner.com/users/lnhdch
We are BLESSED!!!!
DianneOK
Donnelly, ID
Good Sam RV Club
Posted: 11/10/09 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
We have wintered in below 0* in our Teton. We did not skirt, but did heat and insulate the water hose. We would also heat and wrap the sewer line, taking care to use PVC for the sewer line itself, if we do it again. We found the biggest air intrusion was thru the door handle/lock assembly We put down throw rugs in the kitchen and our bathroom area was carpeted. We had a radiator heater which helped enormously.
Would I skirt? Probably, if we were going to be in an area more than a few months....
Dianne
Donnelly, ID
DataStorm
HAM WB6N (Terry)
2010 Ford F350, 4x4 SRW, xcab, longbed (will not be pulling the Teton)
2005 Teton 39' Frontier Grand
Life Member Good Sam
Escapees
Geocache..."RVcachers"
RV net Blog
JakeInc.
Alpine, WY
Good Sam RV Club
Posted: 11/13/09 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to everyone for your advice and helpful suggestions! As you know, some skirting jobs are very well done and others, well, pretty trashy. I've seen some skirts made with styrofoam board that are neatly done and look nice. In my searching I found the following site of a company that sews custom skirts. http://rvskirting.com/index.htm
It appears they do a good job of making custom skirts and they also make panel kits for the DIY'r. Any experience out there with this company or do you have any other recommendations for skirting manufacturers or methods?
