tmmar
Nassau County, Long Island, NY
Good Sam RV Club
Well, I finished winterizing- blew out all the lines, pumped in pinkstuff, added stuff to diesel fuel, polished the rig, hooked up trickle charger to chasis battery, 303'd the tires and put on tire covers and put winter cover on rig. Now I am sitting here and I had a thought. Did I need to blow out the line for the blank tank flush? Will that be ok with out the water been blown out?
2008 40' Forest River Berkshire DP Bunkhouse
eubank
Angel Fire, NM, USA
Sink traps. Outdoor shower plumbing, as needed. And, yes, the lines for tank flush.
Lynn
http://forum.aardvarkrv.com/blog/
Hayduke Lives!
downtheroad
Puget Sound
Another thought: frig ice maker? (if you have one)..
"If we couldn't laugh we would all go insane"
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Picture
Reese Dual Cam HP
Lots of other stuff nobody cares about
Vulcaneer
Northern New England
Did you pump pink thru the toilet flush valve? Each and every faucet, Inside and Outside shower? All P-traps? Ice Maker? Clothes Washer? Empty Water heater tank and bypass it? Empty all holding tanks? Take out all food and freezables? And remove anything a mouse can make a nest out of.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
tmmar
Good Sam RV Club
Thanks to all that replied, but I have done everything that everyone has suggested. I didn't list everything that I did because I didn't want my post to go on forever.
My only concern is whether the black tank flust line needed to be blown out or will it be ok if I didn't blow it out.
weasel4
Alberta
tmmar
I would rethink the term trickle charger as opposed to battery minder charger. A trickle charger will damage your batteries over a long charging period.
BTC
Eagles may soar, but weasels don't get sucked into jet engines.
4*phun*2
Canada
You don't need to blow out the black tank flush line. It should drain on its own.
Glenn & Karen
'06 F350 4X4 Lariat CC LB DRW (nice hips)
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
Gadget Guy
Whitefish/Calgary
You will get your answer next spring on how well you did.
dave17352
LINCOLN, NE
I was just asking myself the same question as I was winterizing my 5th wheel. I haven't the past four years and no problem. But I was looking at it for some reason this year and wondering do I need to blow out that line. I can't see where it would hurt but mine has not froze and broke yet and it gets plenty cold here.
DandSW
West Michigan
Good Sam RV Club
tmmar - If you are referring to the hose fitting for a tank flush system, yes it is a good idea and recommended to blow that out also.
Dave
2010 Newmar CS3647
