RV.Net Open Roads Forum: Tech Issues: Wrong Camco Insect Screen
 > Wrong Camco Insect Screen
Tech Issues Related Tips
tafische
Memphis
Posted: 11/11/09 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Ok - stupid me - I accidentally ordered the wrong Flying Insect Screen for my frig. Camco has two models - 42148 Norcold and 42149 for Dometic.
I have a Norcold, but ordered the Dometic and it is too late to cancel. They look exactly the same from the pic - how much difference is there in size on the two service doors? Can I mod these to fit the Norcold or am I going to have to re-order?
* This post was edited 11/14/09 05:54pm by tafische *
robatthelake
Vancouver Island
Posted: 11/11/09 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
I agree the Picture looks the same! Dometic OR Norcold! I guess You need to wait and see! Good Luck!
Rob & Jean
Dutch Star Diesel Pusher ..Tracker 4X2
FloridaNomad
Posted: 11/12/09 10:20am Link  |  Quote  |  Print  |  Notify Moderator
check you private messages..
Judy KB5GXI and Ray Wallace K4DAB aka Floridanomad
Coachmen Denali/ Chevy 2500 diesel with Allison Transmission
Reese dual cam
Old Town, Florida
Chris Bryant
DeLand, Florida, USA
Posted: 11/12/09 10:46am Link  |  Quote  |  Print  |  Notify Moderator
They are different and not interchangeable.
But.... simply hot gluing screen on the inside works better.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
robatthelake
Vancouver Island
Posted: 11/12/09 11:33am Link  |  Quote  |  Print  |  Notify Moderator
Good Advice Chris!
What size screen would You advise using? Regular door screen seems a bit too Fine would some 1/4 " Hardware Cloth be a better choice or is that too Coarse? Maybe 1/8 would be about right!
Fisherman
Angus, Ontario, Canada
Posted: 11/12/09 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
If you can find 1/8th" hardware cloth(screen) it would be about right, enough airflow but small enough to keep out the mud daubers, cluster flies and yellow jackets.
John&Joey
Northern MN
(Baby it's cold outside)
Good Sam RV Club
Posted: 11/12/09 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
On this topic, you think the same idea will work for the hot water heater also? Or would it restrict the hot air flow too much?
Fisherman
Posted: 11/13/09 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know what the btu output is of a water heater although I've run a bare hand alongside the trailer just above the vent, it doesn't get hot. I do however use the commercialy made stainless screen that goes over the furnace exhaust and it's about 1/8th" square to keep the mud daubers out. I suppose if you cut out the perforated area on the metal heater cover and then replaced it with the hardware cloth, it would be okay. Next problem, how much road dust and crud would get in there while underway, maybe have a removeable cover.
DuckTang
NC
Posted: 11/13/09 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Beekeepers use the same type screen in their hives for some bottom boards. If you have a local independent hardware store or farm supply check there for some and buy it by the foot. I bought a 1' X 3' piece for ±$8.
2002 215 Aero Cub
samandtheduck
On The Canada/US Border
Posted: 11/13/09 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
I put 1/8" hardware cloth in my fridge vents and over the opening in my hot water heater after getting bees in my fridge compartment. I bought the Camco screens for my furnace.
Brian
