RV.Net Open Roads Forum: Class A Motorhomes: receiver into hitch????
 > receiver into hitch????
coffebreak
vegas
Posted: 11/12/09 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
when we place our 2" drop hitch into our receiver on the m/h there is a little play in it up and down and sideways. i called blue ox (that is our tow bar company) and asked them if there was a remedy. they sold me a hitch immobilizer for 50.00 which consists of a flat piece of metal with 2 holes in it in which a square U bolt goes over the hitch threw the holes and you tighten up on the nuts to tighten the hitch into the receiver.
seems to work OK at first but the first trip the bolt broke. i ordered another bolt at 22.00 dollars and that one broke also.
anyone have or use a better method to keep the hitch tightened up into the receiver to cut down on the play in it?
thanks
Deadbeat
las vegas
Good Sam RV Club
Posted: 11/12/09 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
I welded beads on mine and ground them down to just fit into reciever tight.
MrWizard
Van Nuys, Ca
Posted: 11/12/09 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
drill a hole in the receiver, weld a nut to the hole set a bolt into the nut and tighten, use a second nut on the bolt as a JAM nut to lock the bolt in place
these only have to be snug, I suspect you over tighten the factory version and stressed the bolts
Connected via Verizon Via Motorola Droid with Android2 OS
ArchHoagland
Clovis, CA, USA
Good Sam RV Club
Posted: 11/12/09 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
Messed around with this problem on a pickup truck.
They are designed that way so I decided to accept the things I can not change on this one.
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison 1000 transmission
7.1 MPG based on fuel used over 32,000 miles
TOADS
US Gear Brakes
1991 Mazda Miata 5 speed 33MPG 2,310 LBS
UltimaRV
USA & Europe
Posted: 11/13/09 02:51am Link  |  Quote  |  Print  |  Notify Moderator
Second the weld beads. We had the opposite where we had to grind it down initially. I was a bit angry with the grinder then, but after reading your post, I realize how fortunate we were.
Dian, Robert & Precious - Presently RV'ing in Europe!
2000 45' Featherlite Vogue 5000, tag, slide, Detroit Series 60
2006 19' Towcorp enclosed trailer w/60" tongue
2004 13' Ultima GTR (9.9 seconds standing quarter mile)
1fastdad
mo.
Good Sam RV Club
Posted: 11/13/09 08:00am Link  |  Quote  |  Print  |  Notify Moderator
I can not recomend welding or drilling on the receive hitch. The bar and receiver are designed to have movement to prevent the it from seizing in the receiver.
runway18-2
missouri
Good Sam RV Club
Posted: 11/13/09 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Deadbeat & MrWizard s Ideas work. I have done both. I just remove the male part when not in use to avoid siezing.
The thought of liabilty did cross my mind if hitch failed? I do believe that failure is less a probility if the hitch is tight.
The welded one is on the hitch for the toad. The threaded one is one my motor cycle carrier. I think The threaded one is the weakest.
In my opinion, the 5/8 mild steel retainer pin will shear before the mods break.
mccsix
Pensacola Florida
Good Sam RV Club
Posted: 11/13/09 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Cut up a plastic bottle (I use an old oil bottle) into 1" shim strips, insert into sides and bottom. This should quiet the rattle.
MGO BLUE
CAPE CORAL FL
Posted: 11/13/09 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Google " silent hitch pin " they are about 25.00 I use then for my cycle rack and golf cart rack......I add then to every drop down ...no rattle no noise Jim K
Delaine and Lindy
Linden Tn. (The View) /Gulf Shores, Ala.
Posted: 11/13/09 09:28am Link  |  Quote  |  Print  |  Notify Moderator
I think I remember seeing a products that fits on the receiver and it will stop the movement. I think it was in Camping World, not sure but most all receiver hitches do the same. The bead welding is a sure fix. GBY.....
2006 FreightLiner M2
Trailer Saver Air Ride (TSLB2H)
Pressure Pro System
2008 Chevy Silverado 1500 C/C (Grocery hauler)
2009 Chevy HHR LT 2
2010 Mobile Suites 38 RSSB 3/4
www.webspawner.com/users/lnhdch
We are BLESSED!!!!
