RV.Net Open Roads Forum: General RVing Issues: LED Turn and Stop Bulbs
 > LED Turn and Stop Bulbs
General RVing Issues Related Tips
Likes to tow
Huntington WV
Good Sam RV Club
Posted: 11/14/09 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Go to bargman.com and look at their line of trailer lights. They have some quality LED assemblies that are significantly brighter and good looking to boot. When spring comes I am installing a set of the recessed ones in my 5th wheel. We recently returned from our last camping trip and met a fellow in a campground that had made the conversion on his older trailer. There is a remarkable difference in brightness and speed of operation.
pcm1959
St Augustine, FL
Posted: 11/14/09 07:49am Link  |  Quote  |  Print  |  Notify Moderator
I replaced the rear running/tail/stop lamp assembly on my fiver to led assemblies . There are super bright - even in direct sunlight. I have had many people comment on their visibility. I think they are well worth it. pcm
webecreekin
Las Cruces, NM 88005
Posted: 11/14/09 11:22am Link  |  Quote  |  Print  |  Notify Moderator
What about the electrical load of an LED as opposed to an incandescent bulb? Especially in the turn signal circuit?
2006 Chevrolet Silverado 3500 DRW Crew Cab--Duramax/Allison
2009 Cedar Creek 36 CKTS
www.cedarcreekrvownersclub.com
Likes to tow
Huntington WV
Good Sam RV Club
Posted: 11/14/09 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
LED lights draw much less current than incandescent
sirdrakejr
Las Vegas, Nevada
Good Sam RV Club
Posted: 11/14/09 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from 5th wheels to Gen'l RVing Issues.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
TankerDude
West of Middle Earth
Posted: 11/15/09 05:18am Link  |  Quote  |  Print  |  Notify Moderator
While the LED's do react much faster than incandescent bulbs, that reaction time difference is miniscule. Still, as someone else mentioned, getting the stop lights on a little quicker can't hurt.
As Likes to tow said, LED's will draw MUCH less power.
An example: I changed out all the running lights and the stop/turn lights on my TT for LED units.
With the incandescent bulbs, I could plug a flasher into the pig tail between pins 6 & 7 (I think) and could get all the lights flashing. This is good when you get stuck on the shoulder of the road, and when someone is trying to find you in the campground after dark.
Now with the LED's installed, there's not enough current draw to activate that flasher.
I purchased my LED's here.
I really like them, and they are much more visible during the day.
Nice and PC now.
2004 Ford F350 PSD 6L 4x4 Crew Cab.
2007 Jayco Eagle 322 FKS.
Camping with DW Terry,
Bobi-Sue and Billy-Joe,
Westhighland White Terriers
webecreekin
Posted: 11/15/09 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
That is my question. If there is not enough current draw to activate the flasher, what needs to be done to the turn signal circuit to activate the flasher. Or is there a different flasher that is used. I have heard people say that the LEDs can't be used in a standard turn signal circuit. They say that something else needs to be done over and above changing the bulbs. What is that something else?
webslave
Clearville, PA
Good Sam RV Club
Posted: 11/15/09 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
They make special flashers (usually the LED shop will have them) or you can add a resistor to the circuit (again, usually the LED shop stocks these, too). The special flashers trigger at a lower load and the resistors add the proper load to the circuit so that it will work with a standard flasher. Your choice.
You don't mention what kind of rig you are installing these in. If you are putting them in the tail lights of a TT, your TV, having standard incandescent bulbs, will have enough load, on their own, to make it a non-issue. If on the other hand, you have one of the plugs that you use on your TT's 7 pin plug to make the trailer flash when the TT is disconnected from your TV, you'll have to go one of the above routes to have the TT's tail lights flash properly.
Don
Bronwyn
3 Cats - Coco, J-Lo and Ragamuffin
2008 FunFinder X 210WBS
2008 Jeep Hemi Commander Limited
Eqaul-i-zer 10K
Prodigy P3
LAdams
Northern Illinois
Good Sam RV Club
Posted: 11/15/09 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Check out Command electronics... If your taillights were originally made by them, they have a retrofit kit that is very easy to mount and quite a bit brighter than the stock #1141 bulbs...
Mine were originally from Command and the install couldn't have been easier...
http://www.commandelectronics.com/led-tail-lights.html#surfacemount
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
