RV.Net Open Roads Forum: Travel Trailers: Hunter thermostat 42995B...moving to my next mod
 > Hunter thermostat 42995B...moving to my next mod
Travel Trailers Related Tips
mhawk4
South Carolina
Good Sam RV Club
Posted: 11/15/09 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Just finish adding plexy to my screen door time to move to thermostat.
I went to Wallyworld got me the Hunter thermostat 42995B (w/ instructions for a 42999B) now i need the advice.
My Jayco has a coleman-mach tstat with the following colors; red,yellow,white,gray,green,blue
please correct me if i am wrong, now my connection should go as follows;
red not used
yellow to Y
White to W
gray to G
green to RH/RC
blue with switch together with gray on G
I will read all the instruction again, just need to make sure a i am understanding correctly.
thanks for the advice!!
2002 Ford Excursion XLT 6.8L,V10 3.73(TB2)
1999 Chevy Suburban 5.7L,V8 3.73 (BUDDY)
2008 Jayco G2, 27BH (MHAWK)
HP dual cam
Luis,Shelia,Noah,Gabriel
All about the family!!
downtheroad
Puget Sound
Posted: 11/15/09 08:34am Link  |  Quote  |  Print  |  Notify Moderator
This is what I used..it worked great.
Credit to Les Adams
"If we couldn't laugh we would all go insane"
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Picture
Reese Dual Cam HP
Lots of other stuff nobody cares about
hwybnb
Posted: 11/15/09 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I don't know who Les Adams is but the wiring diagram in the above post is from one of my web pages. Here are the complete installation instructions:
Link
firecapt1
Sonoma County, CA
Good Sam RV Club
Posted: 11/15/09 10:46am Link  |  Quote  |  Print  |  Notify Moderator
See here for specific instructions with wiring diagrams for the Coleman Mach to Hunter mod:
Coleman to Hunter Modification
I believe the Duotherm to Hunter is a bit different so make sure you have the right directions!
Frank, Martha & Ryan
2007 Ford F-250 SD Crew Cab
2006 Cougar 289EFS
Happy Trails to you, until we meet again!
LAdams
Northern Illinois
Good Sam RV Club
Posted: 11/15/09 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
Don't know where that diagram came from either - guess someone credited me for your work, but many people have asked to duplicate my original modification/article on their websites to which I have replied yes, but please give credit to myself and Alan Paskey for the original work... Some have made up different wiring diagrams rather than just the text in my article, so I guess somewhere along the way things got transposed and I got the credit for the wiring diagrams...
To the OP - In that you have the Coleman A/C unit and not the Dometic, wire per Alan Paskey's instructions in my original article - click on the link in my signature for that documentation and PM me if you need additional help...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
downtheroad
Puget Sound
Posted: 11/15/09 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Link
Sorry then...but is the diagram YOURS or something you borrowed for your web page?
I certainly have no problem giving credit where credit is due..that's what I thought I was doing.
hwybnb
Posted: 11/15/09 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
The photos, wiring diagram and description are all original by me. I really do not care if I get credit or not but wanted to set the record straight.
chi6488
florida
Posted: 11/16/09 04:14am Link  |  Quote  |  Print  |  Notify Moderator
Should take about 10 mins maybe twenty if you like beer. Simple mod but makes a world of difference
2009 Jayco Eagle 324BHDS
2008 F250 King Ranch 4wd
2005 GLacier Bay 2670 Cat
mhawk4
South Carolina
Good Sam RV Club
Posted: 11/16/09 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Looks like the installation is pretty easy, but i still have 2 questions.
Why you guys are using a simple on/off switch (spst) for the hi fan? the way you are connecting the switch on the hi fan wire does not bypass the low fan when the switch is on; in other words, when you turn the switch on you are sending voltage to fan motor through low and hi at the same time. Using a SPDT (SINGLE POLE DUAL THROW) lets me switch or send the voltage through one cable at a time, hi or low, not both at same time.
For the coleman-mach tstat there is no use for the blue wire, this wire is a ground or negative; to my knowledge all circuits have a negative and or ground for protection. Does changing the tstat to work on DC has anything to do?
mhawk4
South Carolina
Good Sam RV Club
Posted: 11/16/09 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
To downtheroad,LAadams and firecapt1:
Thanks a bunch for your feedback.
Here is what i did, coleman-mach to hunter 4995b mod; hope it helps!
I was going to take the panel to find a place for the switch, then decided not to, i had plenty space between board and wall mount.
The switch i used got it at radio shack it is a SPDT (single pole double throw) toggle switch #275-325. The center connection (i used blue wire) goes to G (FAN), green is hi fan and black wire is low fan (black wire is use to be connected to gray. The switch has 3 positions, center is off and either sides is on.
To install the switch i had to cut some plastic (1/4") from board casing to fit the switch also had to cut a piece of the wall mount base. Some super glue and tightening of nut kept the switch right in place.
I soldered the blue wire to G right on the board.
The final step was connecting
yellow - y
white - w
red - rc/rh
green high fan to switch
gray low fan to black wire on switch.
The blue wire in the Coleman-mach tstat is a neutral, one thing i noticed this wire piggybacks of a neutral coming from top unit, just cap is not needed.
I only tested the furnace and it worked, i will test the a/c later, i do not have a 30amp outlet at the house (that could be my next project)
Thanks again for the help.
