RV.Net Open Roads Forum: Oven Burns EVERYTHING What Can I do to Fix
Search only in Toy Haulers
 > Oven Burns EVERYTHING What Can I do to Fix
Toy Haulers Related Tips
jtgroover
Hooliville #645
Posted: 11/16/09 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Everytime the wife trys to bake something it Burns the bottom of whatever it is, I know make all the jokes you want it is not the cook, we have tried the Baking stone to distribute the heat and that doesnt work it is just to darn hot on the bottom of the oven has anyone else had this issue?
Git-R-Dun
arizonadesertbrat
Where ever the pipeline leads
Posted: 11/16/09 10:56am Link  |  Quote  |  Print  |  Notify Moderator
OK, here is what I have done: I put a cast iron skillet on the very bottom, below the burner, than on the grate, I put a baking stone, then I put a cooling grate on top of that, so the air circulates under whatever I am cooking. I also am careful about preheating the oven before I try to put something in. It seems to help a lot, I have not burned the bottome of the cornbread or the bisquits since I started this routine.
skipnchar
Topeka Kansas USA
Posted: 11/16/09 11:07am Link  |  Quote  |  Print  |  Notify Moderator
By using an oven thermometer you would probably find your oven is running a lot hotter than the dial indicates. We've found that simply lowering the temp to where it's what we WANT it to be instead of using the dial, it does a fairly good job. About the only OTHER concession DW makes is to rotate what she's baking when about half way through.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
Al/Reeni
Ft Myers, Fl
Posted: 11/16/09 11:25am Link  |  Quote  |  Print  |  Notify Moderator
We tried the unglazed tile and it worked OK, until it broke into pieces and we had an oven full of gravel. I replaced that with an insulated baking sheet that with a little bend of the edge, fits between the burner and the rack. That seems to help a lot to redistribute the heat.
Also, after the glass oven door shattered for the second time,
I decided to replace it with a wood front. The original insulation in the oven door was a joke. This piece of cotton was it.
Replaced the original insulation with duct board . . .
and made this wood front.
This seems to have made the biggest difference and the oven heats much more evenly with less flame.
fordsooperdooty
Orange Kounty Kalifornia
Posted: 11/16/09 11:54am Link  |  Quote  |  Print  |  Notify Moderator
The double bottom AirGourmet type baking sheets (insulated type) seem to keep the burning food to a minimum. Placing a ceramic tile sometimes absorbs the oven heat and undercooks the bottom of food, or causes the food bottom to over heat and burn. Smaller sized air insulated baking sheets can be found at Camping World. We also have double bottom muffin pans!
A Jayco is not just an RV, it's a way of life!
mockturtle
Northwest
Good Sam RV Club
Posted: 11/16/09 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Air bake cookie sheet works for me. Never any burned bottoms. You can bake biscuits or cookies on them directly or set a muffin tin, pie pan or casserole dish on top of it.
2000 Born Free 24RB Class C
2002 Honda CR-V toad
Roadmaster Sterling A/T towbar
VIP braking system
Eddyline Merlin kayak
coribdx
on the road
Posted: 11/16/09 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
I would use the air bake sheets JT.. It will act as a cushion between the bottom of the oven and the dish. Second on the temperature guage.
btd35
Spokane, WA
Posted: 11/16/09 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
First of all, I WOULD NOT REPLACE THE OVEN DOOR INSULATION WITH DUCT BOARD AND PUT A DECORATIVE BOARD ON THE OUTSIDE! You're looking for a fire there! Duct board is just that. It is meant for use in ducts, such as warm air ducts, NOT, oven doors that reach many times the temperature a furnace duct gets.
1. Make sure the door is fitting propperly, against the seal all the way around, and the seal is in good shape. Often the problem is just an adjustment on the door hinges. Too much air going out a bad door seal causes the burner to run too often heating the bottom of the pan, and improper air circulation inside the oven.
2. Get an oven thermometer, and check the temperature. Preheat the oven for at least 30 min, then check the temp and compare it to the dial setting. The dial has an adjustment on the back that allows for the proper setting up or down.
Use the middle to upper rack settings for best results.
That is how we do it in the appliance industry.
Tom & Beth
05,Grand Junction 35TMS
99, Dodge 3500 Dually.
928gt
Western North Carolina
Posted: 11/16/09 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
Before our new WW that has the Convection/Microwave, my DW said she made sure to always use the highest rack position in the gas oven and she started with approx 25 degrees lower than she would normally use and adjusted (learned) from there.
David
2007 Weekend Warrior LE3505 Billet Edition
2005 F-350 DRW CC LB 4x4 Tow Boss w/Tow Command
BiGG
MI - WI - FL
Posted: 11/16/09 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Yep .... AirBake You can get them at Target and other stores
Looking for any information available on Del Rey "Sky Lounge" and Kamp King slide-ins for preservation/restoration projects.
