RV.Net Open Roads Forum: Small cracks around the sidewall of trailer tires
 > Small cracks around the sidewall of trailer tires
wjpitura
Lake Country, British Columbia, Canada
Posted: 12/05/10 11:06am Link  |  Print  |  Notify Moderator
I have noticed some cracking occuring around the sidewall of my 2007 Komfort travel trailer tires. We bought the trailer new in June 2007 and from what I can determine the tires on the trailer, Mission Tires were manufactured in late 2006....(DOT #5006).
Last winter while traveling home, we did have a tire separation, (no blowout sound), on one of the tires which left us with just a strip of rubber around the rim, thank goodness. Good Sam got us assistance who installed a new Maxxis tire in its place.
Now before we head south again this winter, given I have just noticed this cracking, wondering whether to replace remaining three tires.
First instinct is to replace them, however the cracking seems more surface, although cracks appear to go most of the way around the outside surface of the tire just an inch or two above the rim, in most cases.
Never had this issue before with either a car, truck or trailer tire, and it has only been 4 years. Presume its the make of tire.....Mission. Hopefully, Maxxis will be better.
Anyway, anyone have thoughts on cracks on the sidewall and need for immediate replacement?
Thanks, appreciate your insight.
-- JP
wa8shc
Parma, Ohio
Posted: 12/05/10 11:09am Link  |  Print  |  Notify Moderator
Those are ST tires, probably made in China
They're 4 yrs old, going on 5 yrs
The cracks are signs of tire dry rot
Only way I'd take those on the road, was for the trip to nearest tire dealer
JMHO
Denny WA8SHC (Rita RIP 10/13)
Siberian Husky Tikanni (Ta'kya RIP 11/13 Princess RIP 10/04 Taz RIP 5/08)
2007 Dodge Ram 2500 Quad Cab 5.9L CTD 3.73/LSD,Edge Insight monitor
2008 Rockwood 8243S 5th wheel
Pullrite 14K Superglide & MorRyde pinbox
Sandia Man
Rio Rancho, NM
Posted: 12/05/10 11:15am Link  |  Print  |  Notify Moderator
After 4 camping seasons my stock ST tires were also showing some minor cracking on the sidewalls so for peace of mind we replaced them with a set of Maxxis tires which are giving us good service. Replacing TT tires every five years or so is about the average life one can expect from ST tires.
wjpitura
Posted: 12/05/10 11:16am Link  |  Print  |  Notify Moderator
They are ST tires (ST205-75K15C) and they are made in China.
Appears today, most trailer tires are made in China or Mexico.
Are there better tires to buy?....Maxxis? and where to purchase,....Les Schwab?
Thanks,
JP
Terryallan
Foothills NC
Posted: 12/05/10 01:13pm Link  |  Print  |  Notify Moderator
-- JP
They are cracked, AND they are almost 5 years old, AND you have already lost one of them. Replace them now. Don't move it till you do. They have served notice, You are on borrowed time. OR. Be prepared to change them on the side of the road, and buy them inroute if you can. It's clear. You are riding on Maypops. Meaning they may pop any second.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
skipnchar
Topeka or somewhere else
Posted: 12/05/10 01:55pm Link  |  Print  |  Notify Moderator
With or without cracks Chinese made tires should be replaced. Just my opinion. The only difference between Chinese tires that haven't blown out and ones that have is that they haven't blown out YET.
coolbreeze01
Redding, Ca
Posted: 12/05/10 02:10pm Link  |  Print  |  Notify Moderator
Thanks,
JP
Schwab ordered Maxxis ST's for me. I up-sized from 205 75R 15C to 225 75R 15E. I have 6" wide OE alloy rims.
2008 Ram 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2014 Sandsport 26FBSL
wjpitura
Posted: 12/05/10 02:41pm Link  |  Print  |  Notify Moderator
Perhaps it is a good idea to size-up on the tires.
What is the difference from C rating to E rating?
If you don't mind, what was the approx cost of 4 E rated Maxxis tires from Les Schwab?
Thanks,
-- JP
fla-gypsy
North Florida
Posted: 12/05/10 04:33pm Link  |  Print  |  Notify Moderator
Replace them ASAP
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
padave
Richland PA
Posted: 12/05/10 04:39pm Link  |  Print  |  Notify Moderator
They would not pass inspection in Pennsylvania. My tires did the same thing on my Roo. manufacturers would not cover. I ended up buying new ones. Good Luck
wife and 2 daughters
2012 Ford F150 SCrew 4x4 Max Tow
2011 Lacrosse 318bhs
Equalizer
former:
Nissan Titan
Rockwood Roo 233
Coleman Westlake
