I bought a 2005 Valhalla Alpenlite last year. Under the sink there is a quick disconnect in the water line that runs up to the drinking water faucet. I'm assuming there was once a water purifier in the line that hooked up between the quick disconnect fittings. My problem is that I've yet to see a purifier housing or cartridge that is compatible with the fittings. Can anyone enlighten me on this issue ?
Thx,
Regards, Allen
2005 Silverado SB, 2500HD Crew Cab, D/A, 42 gal aux tank, Garmin 1490T, XM Sat Radio,
2005 Alpenlite Valhalla, 16K Reese Manual Sliding Hitch,
Tonka the Rat Terrier guards the rig.
Lucky the Chihuahua guards Tonka.
Close...but the quick connects on the Hydro Life are different from mine, which are metallic male & female with a sliding locking collar on the female side.
Allen
Allen, I stumbled across this today and remembered you were having a problem locating a filter for your Alpenlite. Hope this helps! Alpenlite filters
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
