Look at the Dish service. They have a new service which allows for you to start/stop the service when you are traveling or in the coach and not pay for when you are not using it. Also, Dish does not charge extra for HD!
The antenna for HD uses more inut "horns" than non HD so be sure any antenna you decide will receive what you want. All the discussion about roof mounted or free standing antenna set up is valid. If you want the best of both worlds, it is possible to have a roof mopunted antenna and a tripod free standing dish snd cable of whatever length used as a replacement for those times when trees may interfere with reception.
We have Direct TV and a Winegard SK5000 HD system. I would go with the same setup again.
We only have to use an external dish once or maybe twice a year due to being blocked by trees, so I am still carrying the old 18 inch dish for those occasions. It won't pick up HD but for a night or so it's not a problem.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
Dave
Everett, WA
2000 Itasca Suncruiser 35U, F53 Triton V-10
Firestone air bags with Quad control air gauge
Pressure Pro tire pressure monitor
Banks Exhaust
SuperSteer rear trac bar
Olympian Wave heaters (Wall mount and portable)
I like the winegard traveler, dual DVR receiver with HD, DISH service, and a spare portable dish when in the trees (which is almost never).
We can watch 2 stations at once, one in living room is HD, bedroom is standard. That way if the DW wants to watch something different, no prob. The dual receiver will even do PIP! HD is almost everywhere and locals can be had with a short phone call to DISH. We load up the movies in the DVR and even have a terabyte hard drive to save movies to (DISH option). That way if we don't like whats on, we have a library of movies in the hard drive. HD is a must for me, makes me see like I got a new pair of glasses.....especially those tiny football players!
There are several factors to consider. Your best choice is where the factors intersect -- FOR YOU.
(I use the term "dish" for the type of antenna used to receive satellite signs (short for parabolic dish reflector which describes its shape), and Dish Network for the satellite service of that name.)
First: DirecTV, which used to be THE service for RVs, seems to have abandoned the market to Dish Network due to policy and technical changes. Details below.
ANTENNA TYPE -- Uncovered dish, dish in a dome, or portable dish.
An uncovered dish antenna is large. The newest are shaped to pick up multiple satellites simultaneously; this is useful when there are two receivers (or one receiver with two tuners) AND the need is to watch shows on different satellites at the same time (a possibly rare situation). Being large, it picks up weaker signals, therefore it can sometimes work if there's just a bit of tree, or in a very stormy situation, or in a fringe region (satellites don't cover everywhere with equal strength). But an open antenna can only be used when parked. Though it begins with a button push, it can take some time for the antenna to unfold itself, pop up and find the satellites (most antennas aim automatically but it can several minutes of sky-scanning). Also, there must be sufficient space above the roof for the tall antenna to erect itself. Wind is a major consideration. An uncovered dish antenna, being a large vertical surface, is quite vulnerable to wind (common almost daily in some regions). If the antenna is stowed when wind increases (so it doesn't get ripped off the roof, any potential better performance in a storm might be of little actual value.
A dome antenna is a fiberglass dome over a dish antenna, which is smaller (to fit inside the dome) so less capable in two ways. It can aim at just one satellite at a time, so rapidly re-aims as necessary when the receiver channel is changed. The only problem is the (possibly rare) situation of two receivers/tuners needing to view two satellites simultaneously. Also, being a smaller antenna covered by a dome, it's less reliable in fringe situations where the satellite signal is weak. Important is that the dome protects the dish from wind so the antenna can be used all the time. Some dome antennas can track the satellite signal to remain aimed even while driving at highway speed. Because it doesn't have to go up and down, a dome is usually faster to use. The most notorious problem is moisture (dew, rain) on the dome, which can make the signal too weak to use. Winegard's RT8000 series has a round-top dome that supposedly doesn't allow much moisture to collect, but this makes the dome tall the roof. (There don't seem to be published tests to prove this claim.) The RT4000 series is lower but a tad flatter, a compromise. The oldest RT1200 is very flat and known to have the problem.
A portable antenna can be a dish on a tripod, or a small dome. The idea is to set it wherever there's an unobstructed signal, with a cable back to the RV. This can be the only antenna, or a backup in case the roof antenna is obstructed. This takes more time to set up. The antenna must be secured against wind (weights, stakes, etc). It must be aimed, especially tricky for HD which involves precise aiming at multiple satellites at different points in the sky (the portable domes aim themselves). There must be RV space to carry the gear. Also, there are reports of portable antennas being stolen, especially the expensive domes.
No antenna type will work if the line of sight from antenna to satellite is blocked. The very high frequency signals do not bend around obstacles.
CAUTION: Large uncovered antennas can be service-specific, notably the popular Winegard Trav'ler. You must decide on DirecTV or Dish Network before choosing the antenna, and changing later can be very expensive. This is because the services use different satellites in different areas of the sky, so the antennas, designed to pick up all of a service's satellites simultaneously, must also be different in design, size and shape. This isn't a factor with domes, which only aim at one satellite at a time, but quickly re-aim as necessary. (A dome antenna typically has switches to tell it which service is used.)
DOME TYPE -- Today's domes find the satellites automatically; push a button. Some can do this auto-aiming while driving -- in-motion. This is useful if someone wants to watch the bedroom TV while cruising, and/or (more common) to listen while driving to the audio of TV channels and music channels. This can be an alternative to a SiruisXM radio + subscription, saving money. A dome can be used with both DirecTV or Dish Network service (specified via switches), so it is versatile should the service be changed. However, both services use multiple satellites, but a dome antenna can only aim at one at a time. When changing channel the antenna re-aims automatically, so the big downside is when receiving two channels at once (to watch one and record the other, or watch different channels on different TVs); this is not possible if the channels are on different satellites. Whether this is a notable problem "depends".
SATELLITE SERVICE - Dish Network and DirecTV offer almost the same channels, but look closely because there are differences. Dish Network claims to have more HD channels. DirecTV imposes severe limits on how RVers can use it.
Dish Network seems to understand the needs of part-time RVers and offer the ability to pay-as-needed. At least, that's what the advertising claims. But there's quite a bit of confusion and controversy over how it is implemented. There seems to be two similar but not identical services (Flex and Pay-As-You-Go), contradictory details depending who is asked, and a variety of good and poor experiences by customers. Over time the dust might settle, but for now it is prudent to make several calls, ask many questions, and monitor the account closely.
DirecTV does not cater to part-time RVers. It only allows service suspension twice a year, and only for six months, then service will be restarted automatically and must run a minimum of six months. It can be expensive to pay for more months than are needed.
With either service, a new subscriber can get a substantial discount by signing up for continuous service for a year or two, a good deal if using the service for both home and RV.
If a dome antenna is preferred (for in-motion, use in wind, etc), the only HD service choice is Dish Network; all channels are carried on dome-compatible satellites.
In contrast, DirecTV HD is on new satellites that are not compatible with dome antennas. This can take by surprise DirecTV customers who upgrade from SD to HD ("it used to work!"), because DirecTV's old SD channels remain on the old dome-compatible satellites. Only a large uncovered antenna can receive DirecTV HD.
Users who have satellite service at home sometimes transfer a receiver (main unit, or from a spare bedroom) to the RV when taking a trip. This much cheaper than having a separate RV service account, but see the "local channel" note below.
Both services offer receivers that can work in an RV, if there's space. Look carefully at all the costs, up-front and on-going, of each receiver (these companies play whack-a-mole with pricing). Dish offers more receiver choices, including one (211) that is small and intended for RVs, but it lacks certain features.
LOCAL CHANNELS -- Network TV (ABC, CBS, Fox, NBC, PBS) is carried on local TV stations, so regulated by FCC. Local channels are typically included in home satellite service based on the home address. If a home receiver is also used in the RV, at some distance away from home (50 miles is a ballpark) the local channels will NOT work (intentionally). Some RVers claim that on a road trip a call to satellite service can get them to change the local service address (in each town, again and again), but this does not seem to be a sure bet (satellite companies fear the FCC). The official satellite solution is to purchase Distant Network Service (DNS), which MUST be provided in a separate RV account, at higher cost, plus DNS fees.
Or, while on the road, local TV stations can often be received Over-The-Air (OTA) using the RV's crank-up TV antenna. This is free, often provides the best HD picture, provides some or all major networks, and also provides local news and weather, and interesting non-satellite entertainment. Many local stations actually broadcast multiple channels (called subchannels, such as 12-1, 12-2, 12-3, etc), so OTA can bring in all types of interesting programming that is not carried by the satellite services at all. Typical is to find classic TV show/movie networks such as This TV, Antenna TV, Retro TV, and several international networks that are only viewable on OTA subchannels (this varies by town). OTA can work in surprisingly obscure places, because city TV stations often use repeaters to carry their signals into "the sticks".
My preferences (after good and bad tries, but still an "experiment"): Dome satellite antenna, usable even when windy (very common in my part of the world and I'd like to avoid expensive antenna and RV damage). Dish Network is the only way to get HD with a dome antenna. In-motion dome (Winegard RT8000) lets me listen to TV audio, news, music while driving (satellite receiver audio is connected to dash radio system) so I dropped ever-more-expensive SiriusXM. The crank-up antenna usually provides OTA local channels (networks, local news, and "classic show" subchannels). Using Dish at home and transferring the receiver to the RV for trips is much cheaper than separate RV-only service.
What I stopped using: Uncovered dish antenna (Motosat SL-5), because it was often unusable due to wind. Wind has been common at night, so we'd have to stow the uncovered antenna -- no evening TV. Also, we'd stow it whenever we left the coach during the day, just in case, then have to wait 20 minutes for it to redeploy and find the satellites. I dropped DirecTV because it won't allow stop/start of service that matches my RVing schedule (unfortunate policy and attitude change), and because a dome antenna can't receive DirecTV HD (watching SD is a waste of modern TVs).
last
edited 06/19/11 09:23am by TravelHawk *
View edit history
2011 Itasca Sunstar 30W
2008 Jeep Liberty 4x4
2006 GoldenDoodle
U.S. States visited (plus Provinces B.C. and Ontario):
I had a Winegard blow off; pulled the rivets on the dish itself. Got where I was going and couldn't get a signal. Went outside and the arm was going around and no dish! I switched to a Kingdome. But now I need to switch back to get HD . . .
WOW... thanks to everyone for the replies. I haven't had time yet to process all of this, but in the next few days I will have more time to do that. Thanks again!
2011 HR Endeavor 43DFT with a 2012 Chevy Avalanche LTZ "toad".
I have a Winegard Trav'ler SK-3005 for DirecTV. It hasn't ever blown off signal with up to 60 MPH wind gust.
I can't even remember the last time the roof mounted antenna couldn't find the satellites because of trees. About all campgrounds have some spots it will work.
I full time so don't have the extra room to waste to carry a portable dish.
Besides if it would ever happen on a overnight spot. I have plenty of movies on the DVR to watch.
DirecTV HD is on the KA 99 and 102.8 satellites, regular SD programs on the KU 101.
Dish Network satellites are more spread out from the 110, 119 to 129 satellites that can be a lot harder to get in a tree area then DTV satellites that are closer together.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
Banks Powerpack
DataStorm SatMax5 | VMSpc | Pressure Pro
08 HHR LT2
