rcp123
New Brunswick
I am just wondering if it is recommended to tie the corners of electric awnings down during a wind storm. I am not talking about severe wind, but just the usual wind that will come with thunder and lightning storms, rain storms, etc.
The trailer I have is a 2011 Jayco 314 BDS. As far as I know, it does not include the automatic closure option that some electric awning have. I will confirm with dealer tomorrow if my trailer has this option or not. Manual does not say we have it.
I see manual awnings tied down all the time, but have not seem any electric ones tied down yet.
Just curious to see what everyone out there was doing.
Thanks
Ryan & Jessica
2 Kids
rvluversnc93
Thomasville NC
I have thought this very same question. Our new fiver has the electric awning and we haven't used it yet but wondered the same thing. I am not hip on these electric awnings and if ours goes bad or gosh for bid gets torn up I am going to replace it with a manual one!
Happy Camping !!
Derek - FD Battalion Chief
Teresa - Technology Assistant
Hers - 11 Dodge Charger
His - 04.5 Dodge Ram 2500 CTD Q-Cab
(Real Trucks Don't Have SparkPlugs)
2011 Canyon Trail Fiver
RvingMike
Fond du Lac, Wi. USA
I have an automatic awning on my mobile suite and I tie it down all the time. I have the automatic sensor, but turn it off so that I can tie it down. If I leave the sensor on, every little wind gust closes the awning. If bad weather is forecast, I just release the tie down and close the awning. Better safe than sorry. I tie it down because the constant "flapping" on a nice, breezy day is annoying.
Mike
2004 GMC 8100/Allison 3500 Dually
2004 36' Mobile Suite
youroo
waynesville ohio
If yours has auto rain dump,make adjustable carport poles to place under the tube,just like a manual awning,tie it down the same way! Youroo!!
hotpepperkid
Chino Hills CA
rvluversnc93 wrote: I have thought this very same question. Our new fiver has the electric awning and we haven't used it yet but wondered the same thing. I am not hip on these electric awnings and if ours goes bad or gosh for bid gets torn up I am going to replace it with a manual one!
Yea me to
hpk
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS (31') 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
eric james
Sioux Falls, SD
I use "hold-awns".
I don't have auto retraction.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
WandaLust2
TN
youroo wrote: If yours has auto rain dump,make adjustable carport poles to place under the tube,just like a manual awning,tie it down the same way! Youroo!!
How can you tell if it's got an "auto rain dump?"
WandaLust. Retired. Middle TN
Heartland 2011 NorthTrail 28BRS
1993 Ford Dutchman Class-C
dancoppins
Michigan
This past winter I tied down our electric awning most of the time putting it in whenever wind was expected, however, when we got back north we were told by the dealer that to tie down the awning was a very poor idea since the metal arms could be bent...................I plan to tie down the awning in light winds and to use a privacy screen when needed. I have found that our previous manual awnings to be much more efficient than the current electric one since you can tip it and move it when you want to. The electric has one position.........OUT.
ShadySkins
Douglassville, PA
dancoppins wrote: .... I have found that our previous manual awnings to be much more efficient than the current electric one since you can tip it and move it when you want to. The electric has one position.........OUT....
My Carefree Colorado electric awning had adjustable arms. I can tilt it if necessary. I don't bother since it has the automatic rain dump. I do adjust the pitch from flat to down if necessary. My only problem is the door of the TT hitting the awning when it is angled down. Good thing the door is rounded on the edges.
2011 KZ 321BHS
Pulled by a 2007 Toyota Tundra Crewmax 5.7
Connected with a Reese Dual Cam
Stopped by a Tekonsha P3
dan-nickie
Grand Prairie, TX
My electric awning has turn knobs to supposedly lock it in position, although it will still lift up in a little wind.
It took me a while to realize that i could pull one side down a little, then turn the locks.
I pull down the side that the wind is coming from the keep the wind from getting under it and raising it.
You might want to check to see if you can do this with your as it took me a while to realize it could be done.
Dan and Nickie, Four Winds 31p, Retired Jan/2011
