RV.Net Open Roads Forum: Class A Motorhomes: Awning Adjustment
 > Awning Adjustment
voyRVing
Swansea, MA
Posted: 07/05/11 09:08pm Link  |  Print  |  Notify Moderator
Need assistance on adjusting my A&E Dometic 9000 series manual awning. The awning is extending and retracting fine but it needs to retract a few more inches to be tight to the motorhome. Any advice on how to do this safely.
Captain_Happy
Abilene, Texas
Posted: 07/06/11 04:32am Link  |  Print  |  Notify Moderator
You need to put more turns on the springs inside the awning tube. I just did mine. There's a web site that tells you just how to do it. This is how I did mine. Un-roll awning like you always do. start at one end, undo the top support from the bottom support, remove the bottom support from the holding latch on the rig. Remove the lower portion of the bottom support. Now, while someone holds the awning up, turn the support three turns. The back support you turn clockwise, the front support, you turn counter-clockwise. Remember, just do one end at a time.
FEDowner
Simi Valley Ca.
Posted: 05/17/12 08:23am Link  |  Print  |  Notify Moderator
Captain, Do you have a link for the website?
'06 Damon Challenger, Nostalgia Dragster & 28ft trailer,
Calpurnia (born 12-20-06)daughter of Traiano & Jasmine,
At the Rainbow Bridge Sonia 8-30-06 our 1st Neopolitan Mastiff
Dr Quick
M'boro, Tn
Posted: 07/06/11 12:58pm Link  |  Print  |  Notify Moderator
Has this always ben a problem, or something new?
If it is new, it could be that awning needs to be adjusted front to back. Get on a ladder and check if main arms are hitting anything that keeps them from being closed. There is a screw usually near the front of the awning that keeps awning fabric from sliding in track. If both arms are hitting say the front of bracket, it could be that screw is loose or missing. If just one arm is hitting bracket, loosen two bolts that hold bracket and tap it over to clear.
Dr Quick
Pirate
Appalachia
Posted: 07/06/11 04:40pm Link  |  Print  |  Notify Moderator
Perhaps one of two springs has broken.
 > Awning Adjustment
