Techie
Pahrump, NV, USA
Torque wrenches aren't that expensive and yes I own one.
I torque the nuts 2xyear and if a tire has been changed/rotated at 25 mi, 50 mi and then 100 mi.
Have never found one that was a problem BUT just like checking your tire pressure, your oil in the TV, etc., it is cheap insurance.
2011 Airstream Classic Limited 34'
2011 GMC Sierra 2500HD Duramax/Allison SRW
Follow our adventures
camping man
Central Fla.
I just go by the sound of my airgun, because I've been pulling wheels with it so long.
05 Dodge CTD NV5600 6speed (100K Mile Club) / 97 Sprinter 5er
Bigburd
Tennessee
Luke Porter wrote: X 2. Oops X 3.
I torque them and recheck twice. After that they are a bear to "untorque".
X 4
2012 Ford F-450 CCDRW 6.7L
2013 Heartland Cyclone 300C
ol' yeller
Redmond, WA
I check mine with a torque wrench prior to every trip, anytime a wheel is unbolted, and every few days when on an extended road trip. You'd be surprised how often I have found one or two off by a few pounds. It is the side to side action of the tires/wheels as they make turns that loosens the lugnuts. It is a quick safety measure along with a tire pressure check, that can save you untold grief if you ignore it.
I knew a guy when I was a kid who always filled the gas mowers at his rental place with a lit cigar in his mouth. He always said that he never had a problem. That was true until the day he did. He was burned pretty badly.
It doesn't pay to play Russian Roulette with your safety.
1999 F250 XLT Superduty Supercab 2WD, V10 pulling a 2006 Keystone Cougar 243 RKS
Oh yeah, the wife & Beagle come along too!
Bit Bucket
Brookings, Oregon
ol' yeller wrote: I check mine with a torque wrench prior to every trip, anytime a wheel is unbolted, and every few days when on an extended road trip. You'd be surprised how often I have found one or two off by a few pounds. It is the side to side action of the tires/wheels as they make turns that loosens the lugnuts. It is a quick safety measure along with a tire pressure check, that can save you untold grief if you ignore it.
I agree. One other thought: when a trailer is new, it sometimes happens that the lug nut studs never get seated properly. After some driving time and some side to side torque applied to the tires by turning sharp, a stud may then fully seat, causing a loose nut. A friend of mine had this happen on a utility trailer he just bought and the wheel fell off while traveling!
Pat & Karen
Maryland
I torque my trailer and TV wheels. I also draw a line with a sharpie on the wheel and nut. A quick check to see if the line matches up on the wheel and nut, then the nut has not moved.
05 Dodge 2500 5.9 CTD auto
07 Jayco Jay Flight 31BHDS
63 DH Fire Fighter 28 years
63 DW 1st Grade Teacher 9 years
95 DD Equestrian 8 years
2005 Ddog
tvman44
Southwest Louisiana
I own a couple of torque wrenches and torque my lug nuts on my vehicles and %er, boat trailer, and both of my flat bed trailers. I do not check them everyday, just after wheels have been removed and every couple hundred miles after that for 2 or 3 times.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
mike102
Bremerton, WA
I have my lugs and lug nuts marked with a bright color so when i do my walk around before heading out i can look and see if the lug nuts have backed off.
2012 Sliver Creek by R-Vision 26ft BHS
1993 Ford F250 XLT 7.5
LLeopold
Camarillo, CA USA
Prior to each trip, then every couple of days if doing extensive traveling (several hundred miles). Just one of my travel checklist items along with checking the tire pressure, oil level, windshield washer fluid, radiator fluid, etc.
Lou Leopold
2001 Dodge Ram 2500 Diesel Quad, SWB, 3.55:1, Rhino Lining
2000 25' Mallard M-23 5M 5th Wheel
Husky 15K w/EZ slider
Wen PowerPro 3500 Generator in a sound box
And I continue to tent camp!
stoney0264
North Carolina
Larry-P wrote: Just wondering how many people actually torque their TT/5er wheel
nuts.
Do you also check the nuts for tightness before starting out every day ??
How many people actually own a torque wrench ??
I torque mine before every trip
Steve & Tina
3 grown DD's (Don't camp with us much)
Duke (Yorkie)
Bailey (Boxer)
1999 Chevrolet 2500 4x4 6.0L and 3.73
Prodigy Brake Control
2006 Honda VTX1300s (mine)
2011 Kawasaki Ninja 250 (Better Half)
2012 Outback 279RB
