RV.Net Open Roads Forum: Class C Motorhomes: Class C valve stem extensions
 > Class C valve stem extensions
Fixedblade
Northeast Kingdom of Vermont
Posted: 07/27/11 01:37pm Link  |  Print  |  Notify Moderator
Greetings all: I'm dealing with an ongoing problem with leaking valve stem extensions on my dual rears on my 2000 Minnie Winnie. I've had 2 flats in the last year, both from the leaking extension hoses/fittings. The last time was with my brand new tires that were just installed so I've finally had the extensions removed. Those were brand new extensions too. Now I can't really check my rear tire pressures without removing the outside duals. I've seen solid brass extended valve stems, not extensions, for larger Class A tires but nothing for my 16' tires. Any thoughts or suggestions?
Thanks,
FB in Vt.
jbarry
California
Posted: 07/27/11 01:59pm Link  |  Print  |  Notify Moderator
yes...contact "Tireman" or Borg...there is also another company that comes up when you search the forums, so......
Do a search for valve stem extensions...you'll get lots of peoples posts about them.
I ordered and had installed the ones from the Tireman. Love em...takes 5 minutes to check all 6 tires. Used to take half hour because the inside dual stem always got hung up between the tires.
They're not cheap, but I think they're worth every penny.
J
bldrbuck
one or the other
Posted: 07/27/11 02:28pm Link  |  Print  |  Notify Moderator
We are able to check our duals with a truck type guage and fill with a truck inflater. You may want to build a connector that will attach to a passenger car hose for the inflater. We carry a small air compressor that works well.
Grillmeister
BBQ TOUR USA
Posted: 07/27/11 02:36pm Link  |  Print  |  Notify Moderator
J
X2
Show me the GRILL and STAND BACK!!!!
oldtrucker63
Harlan Kentucky
Posted: 07/27/11 03:36pm Link  |  Print  |  Notify Moderator
Yes the Truck type gauge will work, Also a truck inflater too.
Without Trucks,....America Stop's
Gene in NE
Omaha
Posted: 07/27/11 03:52pm Link  |  Print  |  Notify Moderator
Fixedblade - Stop using extensions and replace the mostly rubber stems with longer bent shape steel ones.
I have posted this before - I called a tire shop that sells to large trucks - the so called "18 wheelers". I asked them for advice. They stock numerous (I later saw the bins) steel and brass valve stems, both chromed and not chromed. All different shapes and lengths. Drove my RV to the shop "Midwest Tire". They pulled all 6 wheels "broke the bead" on one side of each rim to replace with their stems (cost $1.89 each). They knew exactly which ones to use. They did a fine tuning of each stem by slight bending with the box of a "box end" wrench. Total cost out the door - less than $75. I believe it was about $12 for the stems and $10 each for labor to install. No tax on labor in this state.
2002 Trail-Lite Model 211-S w/5.7 Chevy (click View Profile)
Gene
visch1
CAPE COD, MA
Posted: 04/08/12 06:52am Link  |  Print  |  Notify Moderator
OldDutchman wrote:
I just installed the "Borgs" from Sixrobbies and love them. Price has gone up recently and a set runs about $96 plus shipping. Worth every dime!
X3
fisher60
Plant City, Florida
Posted: 07/27/11 07:37pm Link  |  Print  |  Notify Moderator
www.sixrobblees.com. Ask for Lindsay in sales. ask for Dually Valve Stems. I have these and have not had to add any air, ever, since installation.
'01 Dutchman Express 28A, Borg Chrome Dually Valve Stems, Pacific Dualies Wheel Simulators, '06 Tuscon, 2014 FLHTCUTG
Good Sam Life Member
OldDutchman
Biloxi, Ms.
Posted: 07/27/11 09:49pm Link  |  Print  |  Notify Moderator
2012 GeorgeTown 351DS...a Minpin, 2 Chihuahua's, and a great wife
Dakzuki
Carnation, Wa, USA
Posted: 07/27/11 05:18pm Link  |  Print  |  Notify Moderator
I have these on my valve stems as supplied by Winnebago. I can check/fill the rears with a dually chuck no problem.
2011 Itasca Navion 24J
2000 Chev Tracker Toad
