RV.Net Open Roads Forum: Class C Motorhomes: Cable TV
 > Cable TV
Cruisineasy
Hayward
Posted: 08/07/11 07:52pm Link  |  Print  |  Notify Moderator
I just bought a 31' Greyhawk. So far everything is great. I'm having trouble trying ti figure out how I can get more stations on my TV at a camp site. I hook up the cable and I can only get 2 - 8. I must be doing something wrong. Also if I raise the antenna I get no signal at all. Even in front of my house..
Any help would be greatly appreciated...
therink
Rochester
Posted: 08/07/11 07:55pm Link  |  Print  |  Notify Moderator
Make sure your tuner on the tv set menu is set to cable, not tuner or air. That is what I have to do with mine.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
hotbyte
Barnesville GA
Posted: 08/07/11 07:57pm Link  |  Print  |  Notify Moderator
On the antenna issue, you should have a antenna booster you can turn on. Look for a little red button & red light on one of the antenna coax plates. After raising the antenna you can also rotate it toward the city with most channels.
Are you setting the TV to the correct input signal (cable vs antenna)?
Our Web Albums Temporary Web Albums
2006 Yellowstone SE, 1998 Dodge Durango SLT 5.2L and 2011 Tidewater 1900 Bay Max
Cruisineasy
Hayward
Posted: 08/07/11 07:58pm Link  |  Print  |  Notify Moderator
Thanks.. Didn't even think of that..
docj
Fulltime--Home is where we park it
Posted: 08/07/11 09:22pm Link  |  Print  |  Notify Moderator
When you are using a digital TV to receive over-the-air (antenna) stations you need to let it find the stations by using the TV's menu and selecting the appropriate function (usually something like "channel scan"); some TV's require a similar scan for cable channels. Our new LG scans analog and digital cable and analog and digital over-the-air and then can retrieve any of them.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
tatest
Oklahoma Green Country
Posted: 08/08/11 07:05pm Link  |  Print  |  Notify Moderator
Usually the TV inputs are wired so that antenna booster needs to be turned off for the signal from the cable input to come through. That may be your no signal at all problem.
The 2-8 problem is about telling the TV turner what band to use. Only analog cable channels 2-13 share frequencies assignments with broadcast channels. If your TV thinks it is receiving broadcast, that's what you get, if it happens to be on the cable (some companies have dropped analog channels).
Analog cable 14-83 are on a band different from the broadcast UHF that use those numbers. If your TV doesn't auto-detect what it is connected to, you need to tell it. There should be a menu option with Broadcast (or OTA or Tuner), and one or more types of Cable. If more than one, most analog cable systems will be on the first one that comes up, the other options, if there, are so the TV can be sold in other markets.
You will get digital cable channels (101-999) only if the TV is digital cable ready, fewer older RV sets are. Then you would get the channels that are not blocked or encrypted. Encrypted channels need to be turned on by the cable company, for an identified receiver based on what has been paid for.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
Robocop
Baltimore
Posted: 08/09/11 08:42am Link  |  Print  |  Notify Moderator
Yes, exactly.
Whenever I am having difficulty getting any good channels on a cable hook-up the first thing I check is the antenna booster. When it is left on it defeats the cable signal. Of course checking all the coax connections is important as well.
Scott
2011 Sunseeker 3170DSF
2 great sons, Scott & Alex (23 & 20)
"Courage is the thing. All goes if courage goes."
crasster
Dallas
Posted: 08/09/11 09:19am Link  |  Print  |  Notify Moderator
Download the manual to the TV from the TV manufacturer. You'll be able to learn the setup procedures for the set. Also make sure that the antenna is an HD antenna.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
 > Cable TV
