ERVSM
Riverside
Howard it is great to hear everything is working out just fine. Thanks for the post, and thanks to Best RV, (Zee) for everything he did to help.
Enjoy your trip, and keep us posted...
digital_art
oc, california
did you used to have a weekend warrior blue mainline? isn't the graphic on your truck from that trailer? either way, nice 5er.
Racorman
Santa Cruz, California
digital_art wrote: did you used to have a weekend warrior blue mainline? isn't the graphic on your truck from that trailer? either way, nice 5er.
You have a good memory.......... yup
I have not seen many of these new Attitudes on the road yet. I just finished building out the battery cabinet to accomodate (4) six volt batteries and also installed a 2000 watt inverter.
AKA..... 56Nomad
Attitude FL28AKLG 5th wheel
2011 Can Am Commander
Chevy 1 Ton Duramax/Allison 4x4 -Edge w/Juice and 4" Exhaust
danojeno
Corona, CA
Can you post some pics of the battery set-up please? I'm so close to buying one I can taste it. Also, have you had a chance to weigh it yet?
2006 Chevy 2500HD 8.1 4x4 CCSB
2012 Eclipse Stellar 28SBG, Spring Over Axle
Racorman
danojeno wrote: Can you post some pics of the battery set-up please? I'm so close to buying one I can taste it. Also, have you had a chance to weigh it yet?
Nope..... but I have a sticker that says it weighs 7800 pounds
I just finished the wiring today.
edited 09/24/11 01:09am by an administrator/moderator *
1slomofo
Corona
I also have attitude trailer... diff model.
BUT just a note on the weight. Throw the sticker away. Both of my attitudes had the same exact sticker inside even though they are completly diffrent years, models and sizes.
Mine says 5000lb's now.... actual is 6970lbs!!!!!!!!!!!!!!!!!!!!!!
-2010 Mosebilt 2-seater Long Travel Sand Car
-2008 GMC Sierra 2500HD Duramax
-2007 Eclipse Attitude 25AK
-2006 Kawasaki Kfx400
-1984 Wife
Chain_dogg
Hoolie Member #19
Very Nice Howie !!...... Digs it
08 F-450 Powerstroke
05 Weekend Warrior LE 3305
06 Yamaha Rhino
06 TRX 450R
06 CRF 450
05 KX 250
08 Harley (Street Glide )
Little red Wagon
Racorman
Brian..... nice to have the thumbs up !
danojeno
Corona, CA
I'm set to pick mine up this weekend, if I can get my hitch in time. Any issues you faced that I should look out for...anything pop up since you bought yours?
Racorman
There were no problems from the Eclipse manufacturer. However there were several items which needed to be fixed or replaced because of defective parts from their suppliers.
1. Dometic Microwave was defective (replaced by Dometic)
2. Fuel pump had a crack in the housing an leaked (replaced by dealer)
3. (3) suspension zerks would not take grease (replaced by dealer)
4. Atwood stove top had a gas leak (replaced by Atwood)
One suggestion..... buy your own batteries. Don't let the dealer supply them.
Everything else looks and works perfect. It is the nicest toyhauler we've owned to date.
Good luck with your purchase!
