RV.Net Open Roads Forum: Tech Issues: ScanGauge
 > ScanGauge
Pokey2
Bel Marin Keys, CA
Posted: 08/11/11 05:55pm Link  |  Print  |  Notify Moderator
I’m thinking of buying one of these but know nothing about them. I assume the ScanGaugeII offers more features (at a higher price) than the ScanGaugeE.
What is the difference, and which model would you buy? Based on what I see on the website, the basic model only offers trip MPG info, which I don’t need. So, is the “II” the way to go?
Thanks, Chris
garym114
Bluff Dale, Texas
Posted: 08/11/11 06:23pm Link  |  Print  |  Notify Moderator
There is much more to the basic scangauge than MPG. The II is the easiest way to get transmission temperature for most vehicles if you don't already have that readout.
edit: Just looked. They don't even sell the original scanguage any more. Might still be available from other retailers. You must be looking at the ScanGaugeE.
* This post was edited 08/11/11 06:31pm by garym114 *
Viewfinder
Western, NJ
Posted: 08/11/11 09:21pm Link  |  Print  |  Notify Moderator
ScanGaugeII is the way to go. X-gauge section
can do many things. Many codes can be found on the net. Must be OBDII not OBD1 unit.
jim
kirbybear
Ft. Lauderdale Fl USA
Posted: 08/16/11 10:41am Link  |  Print  |  Notify Moderator
If you have a Ford 6.0 diesel, you can also read your FICM voltage with the XGAUGE codes.
retired4fun2002
Ellenton, FL
Posted: 08/11/11 07:20pm Link  |  Print  |  Notify Moderator
I bought mine from ScanGuage - and they are there when you have a question and are ready to offer their insight if and when you should need it. ScanGuabgeII is the product of today, and you will not be sorry if you buy one. Safe travels.
wgander
San Diego
Posted: 08/11/11 07:38pm Link  |  Print  |  Notify Moderator
I bought mine so I could read the code when the Check Engine light came on and then turn the light off. Many things that cause the Check Engine light to come on do not require immediate attention and you can't always reset the light.
I normally monitor MPG. I monitor engine coolant temperature when going uphill (the Rockies in summer). I'd monitor transmission temperature but my ScanGuage doesn't have that ability.
If you normally run low on fuel, the estimated miles/gallons remaining would probably be helpful.
2000 Four Winds Five Thousand 28A (1999 Chevy 3500), Master Tow Dolly, 2012 Scion xB TOAD
AZLugz
Mesa AZ
Posted: 08/18/11 01:24pm Link  |  Print  |  Notify Moderator
uh oh.....Guess I better see what I actually have!!!!!!!!!!!
Went and checked some pics.....
WOW...Extreme apologies to you and to the company as I do not have the SCANgage, I have the Ultragauge. It has been a good unit but the company sucks to deal with. Guess I should engage the brain before the fingers!!!!
Again, major apologies.
* This post was edited 08/18/11 01:32pm by AZLugz *
'98 Jeep ZJ (built), '09 F350SD 4x4 Turbo Diesel!
'09 Jayco 345 5th Wheel add-on 5500 Onan, 06 Goldwing ABS/NAV
American by Birth, Soldier by Choice and Christian by the Grace of God
US Air Force Retired
AZLugz
Mesa AZ
Posted: 08/18/11 10:51am Link  |  Print  |  Notify Moderator
Stupidity on my part requires edit
* This post was edited 08/18/11 01:29pm by AZLugz *
jeffcarp
Des Moines, IA
Posted: 08/16/11 02:12pm Link  |  Print  |  Notify Moderator
I read lots of people say that they use ScanGauge to monitor transmission temperature. My question though, which I've not seen addressed, is how do you know what a good, bad and dangerous transmission temperature is? I have the Ford E350 based coach.
2011 Born Free 22' Class C Rear Side Kitchen
AZLugz
Mesa AZ
Posted: 08/16/11 02:33pm Link  |  Print  |  Notify Moderator
I have the II in my Jeep and have used it for wheeling, love it, lots aof great info and its programable
 > ScanGauge
