RV.Net Open Roads Forum: Toy Haulers: 05 Gearbox 335FS stock wheel
Search only in Toy Haulers
 > 05 Gearbox 335FS stock wheel
maak95
Acton, Ca
Posted: 08/16/11 09:49pm Link  |  Print  |  Notify Moderator
OK, I suck at the search. Does anybody know the offset of the factory wheel that the 335FS came with. My TH has 235/85-R16 G rated tires on the factory steel wheels(bought it that way). The measurements that I get are 16x6, 6x5.5 bolt pattern and a 3 5/8 back spacing. The wheels that I'm looking at are the HWT mod 3 16x7 with a -8mm offset. I'm then thinking of running the BFG Commercial T/A 235/85-R16. Your thoughts?
maak95
Acton, Ca
Posted: 08/17/11 10:20am Link  |  Print  |  Notify Moderator
Has anybody replaced their factory tires and wheels on there 335FS? What wheel did you go with? What size and specs? Thanks.
maak95
Acton, Ca
Posted: 08/17/11 05:20pm Link  |  Print  |  Notify Moderator
Found these from my local tire shop. They are certified to SAEJ1204 specifications @ 110PSI.
16x6, 6/5.5 bolt pattern, +0 offset, 4.25 center bore and load rating is 3,580lbs. Run some 235/85R16 BFG Commercial T/A's and I'm good to go.
