RV.Net Open Roads Forum: General RVing Issues: Nitrogen in the tires
 > Nitrogen in the tires
Robin'n'Marian
Edmonton, Alberta, Canada
Posted: 09/06/11 03:36pm Link  |  Print  |  Notify Moderator
The reason you use Nitrogen in your tires is so that you won't have the tire pressure fluctuation caused by hot and cold temps that you do with air, per my DH. He does know what he is talking about, so there is a purpose to Nitrogen after all!
hmknightnc
Wilmington, NC
Posted: 09/06/11 04:33pm Link  |  Print  |  Notify Moderator
Hmmm.....
Pure Nitrogen being an ideal gas would follow the ideal gas law. PV=nRT where P is pressure and T is temperature. It T goes up then P goes up and vice versa. Sorry Robin the laws of physics trumps your answer
K3WE
Missouri
Posted: 09/06/11 04:46pm Link  |  Print  |  Notify Moderator
frankdamp wrote:
As I've said befors, you only need nitrogen in your tires if your RV can do 150 mph for two miles with a dragging brake. (Boeing research - direct experience).
OK, finally a little something that makes sense. Carbon (lots of it in rubber) + Nitrogen does burn.....Carbon + Oxygen does.
I think I am going to contaminate my "pure nitrogen" with some
~80% nitrogen ~20% O2 (+ a host of other gasses in small concentrations)
Too Young to Retire
Sun Diego
Posted: 09/06/11 04:52pm Link  |  Print  |  Notify Moderator
That's what I did! Now I'm concerned about tire failure when I get my rig up to 150 mph and start dragging the brake. Oh what to do.
Chevy 3500HD Crewcab, SB, Diesel pulling a 36' Cameo
gkas
Posted: 09/06/11 05:32pm Link  |  Print  |  Notify Moderator
Nitrogen Fill In Tires = One Born Every Minute
My photos: http://mikekazphotography.com/Gerry/GalleryIndex/index.html
W4MBG
Williamsburg, VA
Posted: 09/06/11 06:07pm Link  |  Print  |  Notify Moderator
actually:
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
pete42
Ohio
Posted: 09/06/11 06:08pm Link  |  Print  |  Notify Moderator
I hold a commercial pilot's license and worked on airplanes during my younger years doing repairs.
we always used nitrogen in plane tires because compressed air has water in it which can and does freeze at the altitudes we flew.
when landing the frozen water can cause a tire to be unbalanced very bad when running down a runway at 150 knots.
my private plane which isn't flown much over 5 or 6 thousand feet and I land on grass runways unbalanced tires are not as bad as when landing on concret.
so if you want to keep the water out of your tires use nitrogen otherwise use compressed air.
pete
Chemgoddess1
Suburbs of Cleveland, Ohio
Posted: 09/07/11 08:16am Link  |  Print  |  Notify Moderator
hmknightnc wrote:
Hmmm.....
However air is NOT an ideal gas. Pete42 nailed it on the head. Unless you are using air that is dried then you have moisture in your mix.
2007 Fleetwood Utah PUP
Me (Pam)
John (husband)
Ian
Ben
Quincy (spoiled rotten Jack Russell)
Chloe (very lucky rescue furkid)
Spike (Iguana eating all the strawberries he can on the other end of the rainbow)
live well, laugh often, love much
mgirardo
Brunswick, GA
Posted: 09/07/11 10:29am Link  |  Print  |  Notify Moderator
I'm not sure I'd use it in a Motorhome, but the last time we had tires put on our Astro minivan, the tire shop put nitrogen in without telling us they were going to do that. I never once had to put air in any of those 4 tires. My Xterra that does not use Nitrogen, I put a couple pounds of air in every month or so.
Since my wife drove the minivan, I was glad to have the nitrogen, since she wouldn't bother to check the air pressure in them.
hmknightnc wrote:
Hmmm.....
You can't argue with Physics, however, air is not always an ideal gas. One of the reasons Nitrogen is better in tires is because it is a dry gas. There is water in compressed air and when there are temperature changes, the water can expand and contract causing the pressure in the tire to increase or decrease. Hence the reason Race car drivers run Nitrogen.
According to Popular Mechanics, there are several reasons Nitrogen is better than air.
-Michael
Michael Girardo :: michael@ecxc.com
2009 Jayco Greyhawk 31FS Class C Motorhome
2006 Rockwood Roo 233 Hybrid Travel Trailer
Four Green Feet
tatest
Oklahoma Green Country
Posted: 09/07/11 01:45pm Link  |  Print  |  Notify Moderator
Can't be down, they tell us the nitrogen molecules are too big to leak out, only oxygen can escape. Maybe they filled that one with air instead, and only the nitrogen is left?
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
