RV.Net Open Roads Forum: Class A Motorhomes: Coach Step bangs
 > Coach Step bangs
PSU_RVr
PA
Posted: 09/12/11 01:00pm Link  |  Print  |  Notify Moderator
When my steps come in or go out, they don't stop when they should and bang 3 times before stopping. When the do stop, they are in the correct position, whether in or out. Is this a sensor that tells them when they are all in/out? Is there an adjuster that needs to be reset?
Newmar Canyon Star 3920 Toy Hauler
Where it's been, the crew -Bandit, Morgan, Sherman. It:
UltimaRV
On Break
Posted: 09/12/11 01:07pm Link  |  Print  |  Notify Moderator
First, check the wires for a break or corrosion underneath or near the door frame.
Dian, Robert & Precious (taking a break - see profile)
2000 45' Featherlite 5000, tag, slide, Detroit Series 60
2006 19' Towcorp enclosed trailer w/60" tongue
2004 13' Ultima GTR (9.9 seconds standing quarter mile)
PSU_RVr
PA
Posted: 09/12/11 04:09pm Link  |  Print  |  Notify Moderator
They are the "coach steps by LCI" - Lippert. And they're not even a year old. Looks like it's back to the dealer.
bsinmich
Holland, MI
Posted: 09/12/11 01:08pm Link  |  Print  |  Notify Moderator
Usually the power motor is a car window motor. Mine is from a '79 LF Town Car. I have 3 steps on my steps so yours could be different. If you don't have Kwikee steps it could be totally different.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
Deetour
Washington
Posted: 09/12/11 01:53pm Link  |  Print  |  Notify Moderator
Interesting..
As I understand step operation, they extend or retract until full limit is reached and the voltage draw on the motor begins to rise. The controller senses that rise and stops the travel readying it for the next call to operate.
Possibly yours simply needs a bit of lubrication to keep it from bumping along.
I'm sure the correct answer is out there somewhere. Perhaps with the next post. Who knows..
harleyman1340
Marietta, Ga, US
Posted: 09/12/11 02:07pm Link  |  Print  |  Notify Moderator
I just fought the same issue with my steps, I have the C&S Coach Steps, the bushings in the motor were bad. Replacement bushings for an automobile power window are available for about 10 bucks, I replaced ths bushings and they worked correctly for about a day then back the same old way (I didn't set the bushings correctly), I was able to get a new power window motor for $50 bucks so I just replaced the motor now I'm good to go.
Sonny, Anita and Phoebe
2005 Mountain Aire 4304
2005 F150 Crew Cab Toad
2009 Harley Ultra Classic
jmduc
Canada
Posted: 09/12/11 04:37pm Link  |  Print  |  Notify Moderator
I had the same problem with my Lippet steps -- the problem was-- control module.
Replaced under warranty. Works fine now.
 > Coach Step bangs
