vdocutter
Troy, MI USA
Alright, this is going to sound ridiculous, but I can't figure out how to get to the bulb. These light fixtures (2011 Komfort 3530FBH 5th wheel) are round, almost flush with the ceiling with a little bulge for the bulb. But the surface has no holes! I can pull the fixture out a little more than an inch, but it feels like it's held in by a spring.
Anyone familiar with these fixtures? How do I get at the bulb?
Thanks very much,
Mike
Mike McPhail
Troy, Michigan
2005 Chevy 2500 diesel
Troy, MI
2007 GMC 3500 Duramax Dually
katysdad
Virginia
not sure if same light that i was working on the other day but sounds similar, try to unscrew lens about quarter turn.
Dodge Ram 3500 DRW Diesel
turninghawk
Orlando, FL
Change a light bulb?
You'll need 288 politicians.
1 to properly explain how to do it
and 287 that will argue that it's the wrong way even if it isn't!
Tsalla Apopka
Crystal River, FL
I've seen similar fixtures that do in fact have a spring on each side.
The springs in the fixture that I'm familiar with allow the cover to pull down and then you reach in from the side and sqeeze the two arms together to pull it the rest of the way down. Hard to describe.
Denny & Karen
Florida's Beautiful "Nature Coast"
Brit,TDI,BH & Claire,TDI (Belgian Sheepdogs)
Merlot - Sheltie rescue
Glady(Morgan Mare - retired),Toes & Beemer(Barn Cats-retired)
WA4OMG (Old Mangy Goat)
SCVJeff
Santa Clarita, CA.
Jeff - WA6EQU
oldchief7155
VA
Try grabbing the outer ring and twist counter clockwise about 1/2 inch.
Delaine and Lindy
Linden Tn. (The View)
Thats correct, push up slightly and turn counter clock wise. When replacing the bulbs may sure not to touch them with you bare skin, it leaves oil and they want last as long use something to hold the bulb. Keep spare bulbs use will need them. Happy Trails....
2012 Chevy Silverado 3500HD DRW's LTZ ******Traded******
Trailer Saver Air Ride (SOLD) (Sold)
2010 Mobile Suites 38 RSSB 3, with vanity slide (SOLD)
"Montana" our Sweet Furr Kid
12/21/10 "RIP" miss you!!
We are BLESSED!!!!
No Hurry-No Worry
Santa Rosa
A pic would help. I ran into this on a rig a few weeks ago. Same type of light fixture. There is a ridge or lip about 1/4" bigger than the glass and I had to get a sharp pointed tool and pry ever so carefully. The glass and surrounding flange dropped down and gave me access to the bulb. By the way, the bulb was not blown and tapping on the fixture brought the light on. That fixture and 7 others in the ceiling all came on after tapping on them. Strange stuff. Good luck and try tapping.
2001 Monaco Executive
500 Hp w/tag axle
2001 Jeep Grand Cherokee Limited
Me,DW and Panther, the coolest cat in the world
KendallP
Grants Pass, OR
turninghawk wrote: Change a light bulb?
Or 2 bartenders...
1 to hold the bulb and 1 to drink 'til the room spins
Or 5 guitar players...
1 to screw in the bulb and 4 to sit around saying, "I could totally do that."
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (with no payments)
ronfisherman
SE Michigan
Keep pulling down to get complete fixture out of its mounting.
Here is what it looks like when removed. Recess Can Light.
Make sure that your fingers are out of the way of spring retainers. They snap down like a mouse trap.
As already stated. The lenses is a twist lock piece of glass. You may need to pull down on fixture and hold housing to get lenses off.
Kodiak Chassis Class C Forum
