OSCBRADLEY
Houston Texas
So I'm sitting here getting ready to line the dog house with some additional heat guard and for the life of me I cant get the darn cover to release!! it's clear everywhere except for back edge, it wont budge. I looked underneath the coach and there does look to be some type of latch there but it cant be reached by human arms anyway, what am I miising here?
2000 Itasca Suncruiser
rvten
Crossville,TN
When we had a Adventurer. There is an Allen screw holding the fron edge of the cover. (you may call it the back edge) It is hard to find in the carpet. You should have an Allen wrench in your owner packet.
This was also on a WH chassis.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
kd7cxg-2
Pacific NW
Lance
Feel around the back edge of the doghouse. Near the center about 1/2" above the floor you should find a small hole. There should have been a hex wrench that came with the MH, it's either 5/16" 0r 3/8" IIRC., it is used to release the rear catch. My MH also had two screws in the front edge of the dog house about half way down from the top.
Hope this helps
Tonm
2002 Winnebago Brave
Toads: 2004 Jeep Liberty, 2010 Toyota Corolla
Ultra power mod,Aero Turbine Mufflers,
Rear Trac Bar,Saf-t-Plus
Ultra Trac Bellcrank, Park Brake Upgrade
Good Sam Lifetime Member
Daboo
Texas Panhandle USA
My 03 Adventurer has the hole in what I call the front of the cover ...there is an allen wrench in the console...you have to feel for the hole, in that the carpet covers it...what I call the front is the side facing the back of the rv(does that make sense)..after turning the holder, you must pull the cover toward you, in that there are clips on the end of the cover...I had a problem locating it the first time I tried to remove it...but the hole is there....
Served proudly 1957-1965..U.S. Air Force
OSCBRADLEY
Houston Texas
found the hole but cant seem to find any screw whatsoever, tried many different sized allen wrenches, no joy.....
T18skyguy
Eugene, OR
Just wondering if it could be a sheet metal screw of some kind
Retired Anesthetist. Pilot with mechanic/inspection ratings.1996 Jayco C 22 foot with 460/Banks Powerpak/Bilsteins.Wife and daughter. Two cats which control my life. 1975 Ford F-250, 84 Coupe Deville, Thorp T18, tons of tools and tons of junk.
YC 1
Yuba City Calif.
OSCBRADLEY wrote: found the hole but cant seem to find any screw whatsoever, tried many different sized allen wrenches, no joy.....
It may take a very large one. Like 3/8 inch wide or so.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
kd7cxg-2
Pacific NW
I just went out and checked mine, it takes a 5/16" allen wrench. The short side of the wrench is approx 2 1/2" and the long side is approx 4", it is not a standard size allen wrench. A standard size could be used if you put the long side in the hole then used pliers on the short side to get leverage.
Tom
OSCBRADLEY
Houston Texas
Well I just couldn't get it so I called a Winnebago parts place and they told me there is a special tool for it, so for $10.00 I ordered it, should have it early next week. Hopefully it will do the trick. Thanks to everyone for all the input, as always I really appreciate it.
427435
Rochester, Mn
The $10 tool will be an $1.50 allen wrench. Mine (same MH as yours) was left in the console on top of the dog house by the previous owner.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 74,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
