EMD360
Tempe, AZ
Ours had similar behavior and getting a new set of batteries solved it. Turned out our connections were not ideal and one of the two batteries was dead. No problems since the new batteries.
We're hooked!
2003 Itasca Spirit 22e
stage
Weirsdale, FL, USA
PaulJ2 wrote: First try this. Remove the circuit board edge connector wire plug. Clean the circuit board contacts gently with an eraser. Worked for me.
2X
gkm3181
Alabama
Had a similar problem several years back with a different brand furnace. After 5 repair shop visits I was given no solution except removing the outside cover and pressing the reset button. I am not a mechanic, but started searching for any problem and found that the duct lines that carried the air to the bathroom and bedrooms were not connected at the furnace. I connected the two lines and problem solved. Apparently the extra hot air blowing in the furnace compartment was causing a hight limit control to trip, thus the reset fix.
alliemac9
Colorado
We had a similar problem. Would start up the first time, usually, but then all subsequent calls from the thermostat you would hear the whoosh of gas and a few clicks and then nothing - it would go to fault mode. We'd have to turn the thermostat off to reset it. My DH didn't get a lot of sleep at the beginning always futzing with that thing.
We changed the circuit board - didn't help. I think it was the second person who looked at it who noticed that the ceramic shroud on the ignitor had a hairline crack, so the spark wasn't really going where it should have been. He replaced it and we've had no problems since!
2007 Coachmen 2430DB + 2 people + 2 dogs
skimask
ND
alliemac9 wrote: I think it was the second person who looked at it who noticed that the ceramic shroud on the ignitor had a hairline crack, so the spark wasn't really going where it should have been. He replaced it and we've had no problems since!
Ignitor would warm up, crack would open up a bit causing a "misfire" ???
Interesting.....
nicpaige
Ohio
Does the unit have to be removed from the rv to get to the ignitor?
alliemac9
Colorado
nicpaige wrote: Does the unit have to be removed from the rv to get to the ignitor?
Hmmm...you know, I'm not certain. For some reason, I assume no. It just didn't seem like that invasive of a job. That said, I wasn't there when he did the work and that was at least 18 months ago at this point, so I don't remember the details very clearly.
