Sean Boburk wrote:
Had a couple Maxxair II covers installed at my local RV dealer when I was having some warrantee work done. This last weekend we went up into OK to go camping...when we raised our awning, my wife noticed a nut that fell down. So when we got it home, we put the awning out, and I climbed up on a ladder to see if I could figure out where it came from. When I did this, I saw another up on top where the awning mounts to the TT. I climbed up on the roof, and could not figure out where it came from. Then I thought about us having the vent covers installed a few weeks ago...so I pulled the pins on them and flipped them up to take a look. This is what I found.
I thought it was optional to screw the bracket to the roof, but I thought you were supposed to screw them to the vent shroud...
Nice crooked bracket...
Why is that little hole in the sealant, and does it go through the roof membrane...
Again, no screws in the vent shroud
Looks like a swing and a miss on the first placement. Yes, they put a screw into my roof, and did not reseal it when they moved it.
Took three tries to get this bracket in the right place. Again, does not look like the holes are sealed.
And again...
None of the screws into the vent shroud
I found two washers under one of the vent covers. So I take it the two nuts we found, were some of the hardware they left behind when they did not install them in the covers. I have probable been dropping the rest of the hardware while driving down the road without knowing it.
I guess I should be thankful they left all the hardware up there, or I might not have noticed the holes until I had a leak. I think the covers have kept most of the rain out of them. What kind of sealant do I need?
Sean
