blackf3504dr
Leesburg , FL. .Lake
Pirate wrote: Before you bother with ANYTHING, put on trac bar, front and back if available for your year. Then, start fixing things if needed after that.
I don't get putting a track bar on a leaf spring suspension. Unlike a coil spring suspension where the track bar keeps the axle centered and from moving side to side on a leaf spring suspension the springs hold the axle from moving side to side..... I can't see spending money on something that's not needed, I know a lot of guys swear by these things. Anyone explain it to me ?
Mom , Dad , Scooter & K.C ( killer cat )
'96 F350 4dr. Dually, 7.3 5sp.
'92 Holiday Rambler 34'
REAL TRUCKS DON'T HAVE SPARKPLUGS !
Al's R/T
Montreal
Unfortunately there is no second holes on the front sway bar, 1997 down F53...
I installed Firestone Ride Rite air bags w/compressor on both front and back on my 1997 F53 and it improved handling tremendously also a a much smoother ride , exiting Interstate is not a scary experience anymore ! a lot more stable in side wind or when a semi overtakes me; when I installed the kit in the rear, I also noticed sway bar bushings were shot so I replaced them as well with urethane ones.
The sweet spot for my mh is 35 lbs in the front and 65 rear.
One other benefit of these bags is there is a slight leveling capacity and i can deflate the rears and inflate the fronts so the mh leans back, helps when dumping tanks
Alain from Montreal
1998 Coachmen Mirada 300QB F53 460
2001 Suzuki Vitara Convertible (toad)
2010 Challenger R/T Hemi
2008 Mustang Bullitt
edited 10/18/11 09:23am by Al's R/T *
jkapril
Las vegas, nv
If the shocks have never been replaced, I would change them. I have a 97 and replaced the shocks and it is night and day! The shocks I took off were shot. Does you rv have airbags in the front springs?
97 35' Four Winds Infinity P30
Al's R/T
Montreal
Ford chassis have leaf springs front and back no coils like your P30
Alain from Montreal
jkapril
Las vegas, nv
I would say shocks and airbags. I couldn't imagine mine without the airbags.
Al's R/T
Montreal
I had replace the original shocks with Bilstein last year, it did improve cornering a bit but the ride was a little harsher, the air bags improved all those points altough it is a more expensive option, especially with the compressor and inside switches and gauges...but i like it !
Alain from Montreal
buschnut
California
I have shocks and springs in the front and springs and leafs in the back.
Chris and Laura
Barley and Hiedi "The RV Pups"
98 Winnebago Adventure
2007 Chevy HHR
Pirate
Appalachia
blackf3504dr wrote: Pirate wrote: Before you bother with ANYTHING, put on trac bar, front and back if available for your year. Then, start fixing things if needed after that.
I don't get putting a track bar on a leaf spring suspension. Unlike a coil spring suspension where the track bar keeps the axle centered and from moving side to side on a leaf spring suspension the springs hold the axle from moving side to side..... I can't see spending money on something that's not needed, I know a lot of guys swear by these things. Anyone explain it to me ? It's all in the size of the box. You have a giant box only held on by leaf springs. There is bound to be side to side movement. Ford knows it, they put a trac bar on the front of my 06. Why they didn't put one on the rear is beyond me.
