esfd243
East Syracuse, NY
I have a 2011 Cougar. Does the fresh water tank only fill from the fill neck that runs to the outside of the rv? I know how to fill it but I only use water in the tank when we go to FW. I just openned the drain to make sure it was empty and it drained for like 30 minutes. I have not put water in this tank since last fall and I drained it last November. Is there a possibility that there is a bypass or something that is open? We only camp at places with hookups and are usually within 6 hours or less so we dont carry water with us. But I was thinking the water running in the system from the public hookup was back feeding or a valve open or something like that.
Mike, Dawn & Mallori
2011 Keystone Cougar 324RLB (1st 5th wheel)
2012 Chevy 2500 HD D/A 3.73
45Ricochet
North Idaho
Sure doesn't sound right
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
bpounds
Whittier CA
There is no internal bypass fill on a Cougar, so it has to be leaking past the check valve. Probably inside the pump. I suppose a small amount of leakage is common and could be considered normal, or at least common. I'm thinking it is a very small leak, over a long time, and that is why the overflow was not breached.
And BTW, 30 minutes to drain is not surprising. They leave a stub of hose with a capped fitting on it for draining. And it is slow. I removed that and installed a plain plastic pipe plug in the tank. I get a little wetter when I pull it, but it drains twice as fast now.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
whiteeye42
Rock Springs Wyoming
more than likely the check valve that is in the line behind the city water hook up is bad and allowing the water go to the tank or maybe the check valve that is in the water pump is bad and allowing to back feed to the tank.
Me,Wife two boys ages 24 and 21 also two dogs
2008 Dodge Ram Quad Cab 4x4 DRW 6.7 cummins
2008 Jayco Eagle 341 RLQS 37' with B&W turnover ball & companion hitch
using rotochoks
add state map
Coyotecprs
chicago
If that was the case then water would come out of the overflow when hooked up to city water. There could be a valve that allows the city water to fill the water tank but it would need to be shutoff once the tank is filled. If the check valve has a slow leak it maybe possible to fill and have overflow without noticing the overflow. Are you sure you did not fill it at some point?
2005 Dodge Ram 2500, 5.7 Hemi
2007 Jayco Jay Flight 30.5 BHS
skipnchar
Topeka or somewhere else
Your water pump may have a bad diaphragm Has it been cycling when no water is being called for?
TMBLSN
Washington State
Are you sure that you opened the fresh tank drain, or the low point drain?
My Jayco had both. One drained the tank and the other just drained the pipes; if pressurized by city water, would drain indefinitely.
Were you connected to city water when you opened that drain? Try disconnecting city water. This is really the only way to know anything about your situation.
2001 Bigfoot 24DB (Class C)
2006-2011: 2006 Jayco 275BHS (5th wheel)
2002-2006: 2003 Northern Lite Ten-2000CD (truck camper)
2002-2011: 1998 Chevrolet C2500HD for hauling camper and towing 5er
Lee
overhill7
Oregon
skipnchar wrote: Your water pump may have a bad diaphragm Has it been cycling when no water is being called for?
X-2
esfd243
East Syracuse, NY
Thanks everyone. The water pump was new in June, it was replaced under warranty. The service place just told me that the service tech probably didnt empty the tank after he installed and tested the new water pump. They also stated that the new pump could be bad too, soooooo just keep an eye on it. LOL. Typical reponse to everything. Thanks for the imput.
