The rule of thumb is to get LED that are around 380-500 LUMENS and are of the WARM WHITE color which should duplicate the 40 WATT indescent bulb. I also am using the LED board from Ebay/China for 4.99 a board. They stick up inside the ceiling lights and have the adapters to plug into the 12VDC.
Dont go buy a bunch of any of these until you get one that works good for you. Just buy ONE. If they dont list the LUMENS then they are probably not bright ones... A whole bunch of info on here just search for LED...
You will get an 80% power savings switching over. A REALLY BIG DEAL actually for camping off the power grid...
My Posts are IMHO based on my experiences - PM me Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
clev wrote: The link listed the 1156 @$15 and I have about 14 to replace. I'd like to find them a little cheaper.
If you want bright lights to replace 1156 bulbs, give these a look. White 102 LED bulb
The 1156 102 LED bulbs are a good choice.....and low cost. I had 4 of them arrive yesterday. Inside the TT they gave a bright white light with a slight tinge of blue. Outside in the porch light, etc, they gave off a very bright white light that was good for illuminating the surrounding area. That's where I'll use them.
I was looking to replace the florescent fixture over the TT sink. After much research, found the new Kaper-11 fixture LEDs. Perfect in my opinion. Double and single models available. Even a single unit with a Night Light built in. The light given off is a soft white light with no blue tinge. The lens cover has a pattern etched into it that helps soften the light and spread it out. Yes, replacing the whole fixture is pricey but I only have 4 to replace, so the upgrade will be worth it to me in my '05 Bigfoot. And they're on sale right now at Panther RV.
I purchased a bunch of these exact same lights from the same vendor on eBay...actually three separate orders. I'm really happy with the lights. They are very bright. They are a "warm white" - not exactly the same as an incandescent bulb, but close enough to keep my wife happy. What I really like is the low power draw when we're boondocking! I have no hesitancy in purchasing more of these lights if needed for something else.
Alfred
2005 Sightseer with Workhorse, ReadyBrute Elite towing 2003 Honda CRV
Map below shows states where we actually camped.....
