RV.Net Open Roads Forum: Fifth-Wheels: Super glide fifth wheel hitch
 > Super glide fifth wheel hitch
kathyjlaw
Tennessee
Posted: 10/27/11 10:24am Link  |  Print  |  Notify Moderator
We have a Super Glide hitch for our short wheel base truck. This is not a "brand new" unit, had it a while. But we are having increasing problems hitching and unhitching. The grears along the glide keep locking in and won't let me hook up securly. (or at least that is what I think) Anyone else had this problem?
Boxer Lovers
Hackett, AR
Posted: 10/27/11 11:22am Link  |  Print  |  Notify Moderator
Just put a new one in my tow, so no experience, but while researching this hitch comments were made by those who owned them that it needed to be on relatively level ground to hitch up easily. If that's not the case you may need to contact Pull Rite. It may need an adjustment.
Dave & Robin
Boxers; Big Jake (2002-2011)& Lady Katydid
Grey Cat: Big Papa (aka) Stinkley
2012 Dodge 3500 Club Cab Long Horn edition
Max Tow, 4:10 rear end,
2007 DRV Select Suites 36TKB, Trail Aire Tri Glide
KJM4
TEXAS
Posted: 10/27/11 11:32am Link  |  Print  |  Notify Moderator
Do you ever lubricate the 5th wheel plate "gears"? You should lubricate them periodically with WD40 or 3in1 oil. I take my entire hitch apart annually and check everything and lube it up nicely. I have the 18k superglide.
I would pull the 5th wheel plate off and flip it over to make sure it isn't all gunked up.
http://www.pullrite.com/pdfs/4100_4400_SG_OM.pdf
B.Sjulestad
Posted: 10/27/11 11:41am Link  |  Print  |  Notify Moderator
I have the 18K pullright superglide and if I am not on level ground I also have had issues hooking and unhooking. Great hitch though.
Bob & Dianne
2011 GMC Denali HD Duramax
2012 39' Cedar Creek 36RE
Emmy and Maddie
DRSmart
Ontario, Canada
Posted: 10/27/11 12:09pm Link  |  Print  |  Notify Moderator
As mentioned, occasional cleaning and lubricating of the mechanisms is encouraged.
Are you able to trip the coupler by pushing on the trigger just inside the kingpin opening on the hitch? Use something like the tip of a screw diver, but not your fingers. If it works repeatedly without a problem it could be your pin-box height when connecting. I used to have a problem once in a while until I learned to have the trailer pin-box low enough to cause a downward pressure on the hitch plate when connecting. The truck may actually drop a fraction of an inch indicating there is some downward pressure on the plate. If the pin-box is even slightly off the plate during hitching, the big ring on the bottom of the kingpin may be too high to hit the trigger properly.
2004 Dodge 3500, Cummins HO QC SB
3.73 Dif, 48RE Auto
Line-X bed liner
Pullrite 16K Superglide, Prodigy
2011 Montana 3465SA Mor/Ryde Pin box
RamTX
Houston Area
Posted: 10/27/11 12:21pm Link  |  Print  |  Notify Moderator
I second this recommendation. I inspect, clean any dirt or other accumulation off the "gears" and surfaces and then spray it with WD40 several times a year. A word of caution: Use a wooden stick to trip the hitch mechanism to the closed position before cleaning it as you could have a serious finger or hand injury if you accidentally trip the locking mechanism closed while cleaning it. This will also provide you an opportunity to observe what might be wrong with the actuating and locking parts of the hitch.
2005 Dodge 2500 CTD ShortBed Quad Cab
08 Jayco Eagle Superlite 31.5FBHS
Line X
Superglide Hitch
Prodigy Brake Controller
gmctoyman
Lake Livingston, Texas
Posted: 10/28/11 11:22am Link  |  Print  |  Notify Moderator
I also have a 18K. A couple of months ago I hooked up, the handle tripped, I did a pull test against my roto-chocks (grandson and wife hollering that I was sliding the trailer). I then pulled the chocks and pulled out of my space, turning SLIGHTLY to the left, the trailer came off of the hitch within 6 feet. Ruined the tailgate, and I ripped a chunk out of my seat. I have an engineering background and studied this from every angle I could, but could not identify the cause.
Dave W. AKA "Toyman"
KE5GOH - On 146.52
RV's ? What RV's ???
Apache Pop-up
Classic GMC Motorhome
07 Leisure Travel Sprinter
Do Boats Count ?
pyoung47
MO
Posted: 10/28/11 11:47am Link  |  Print  |  Notify Moderator
It's important to remember to back into the hitch with as little angle in respect to the trailer as possible. As another poster indicated, it is also good practice to exert some downward pressure on the hitch when sliding into the trailer, since this will prevent High Hitching.
Pullrite customer service is very responsive, and I would not hesitate to phone or email them with specific questions.
Regarding the poster who pulled out of the hitch -- that's pretty unsettling information. If you determine what the cause of this malfunction was, I'm sure everyone would be interested.
ol Bombero-JC
Posted: 10/28/11 12:14pm Link  |  Print  |  Notify Moderator
Yes - we would be interested!
"gmctoyman" and the OP should call customer service (and update this thread)!
BTW - there is a Bedsaver available for PR SuperGlide hitches.
RamTX
Houston Area
Posted: 10/28/11 12:38pm Link  |  Print  |  Notify Moderator
Did this happen with the jaws of the hitch locked around the kingpin?
