RV.Net Open Roads Forum: Do It Yourself Modifications and Upgrades (DIY): Inverter installation
ez2endo
Northern Illinois
Posted: 10/28/11 01:03pm Link  |  Print  |  Notify Moderator
Hiya Guys,
I would like to install an inverter in my fifth wheel so I can watch a couple of hours of TV after the generator is down. What do I need to do? I am sure I am not the first person to request this info. Is there a spot can I go to check past posts on the subject?
Leo \\\ot0
2001 Carraige 5th Wheel - 32XL
1999 Ford F250 "Green Machine"
www.Affordablebackflow.net www.justxr.com/ez2endo
donn0128
Pronounced Ore-gun
Posted: 10/28/11 01:16pm Link  |  Print  |  Notify Moderator
Use the search function above.
It is not only the inverter install it is also sufficient battery capacity to power the converter.
On my fiver i installed the inverter and then bought two 25 foot extension cords, two remodel boxes, two outlets and two covers. locate the box where you want inverter power, and run the extension cord from the plug in on the inverter to the box and wire up the outlets. Just be sure to install a fuse between the battery and inverter, and to make the 12VDC runs as short as possible using sufficiently large gage wire.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
RoyB
King George, VA
Posted: 10/28/11 01:44pm Link  |  Print  |  Notify Moderator
I have found that Inverters will drain a single battery rather quick. Got to watch that like a hawk.
What I did was install a PSW 400W INVERTER hardwired as close as I could get it to the Battery switch but still be inside the trailer. Then I ran an extension cord from the 400W INVERTER to the HDTV/DVD cabinet location and just plug the TV units into the emergency power extension cord when I needed it. I would turn the INVERTER ON when I needed it. This setup will run several 120VAC items like your HTDV, DVD, A 120vAC 15W Lamp, your cell phone chargers, small fan, etc... this is the simple way to do it. Your trailer Battery will continue to run the 12VDC appliances like the ceiling lights, water pump, etc.
Or you can install a few more trailer batteries and install a 2400W-3000W PSW Inverter close to the battery switch and install a switch-over relay at the Shore Power Power Distribution Center and switch the whole trailer over to the Inverter which might give you four hours of use before it completely runs down your battery bank. Large Power Inverters draw serious amps when used to their full rated values...
You will hear several different opions on whether to use a PSW or MDW type Power Inverter. Some get by ok with either one. I blew my electric blanket controller using MSW type the first time I plugged it in. Read up on google on PSW verses MSW POWER Inverters and make you own decision on that.. The PSW Inverters will run anything so I went with that which does cost alittle bit more but I dont have to worry about it burning out anything I plug into it.. (Including my expensive HDTV and DVD units). Modified Sine Wave Inverters doesnt like anything that has AC motors or AC transformers involved and will tend to heat them up. (Fans motors, Cell phone chargers, etc.)
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
2oldman
Winchester WA
Posted: 10/28/11 02:08pm Link  |  Print  |  Notify Moderator
Don Rowe site Inverter FAQ
Inverters by Phred
inverter thread
MSW v. pure sine
w6pea
Posted: 10/28/11 03:46pm Link  |  Print  |  Notify Moderator
X2
If We Can't Haul It....You Don't Need It ! Motor-T
Remember "Without Trucker's America Stops"
"Buy American Made Only!"
It's too late to save your shoes..roll up your pant legs
"When all else fails..Amateur Radio"
I need more Coffee & Old Bushmills
If We Can't Haul It..You Don't Need It. Motor-T
Semper Fi
jspringator
Versailles, KY 40383
Posted: 10/28/11 04:39pm Link  |  Print  |  Notify Moderator
If you have a cigarette lighter plug behind your TV, then just get a small plug in converter at Walmart. It works my flat screen perfectly. Definitely would not have enough power for a tube type TV or a plasma.
Jim & Sherri
05 Jayco Eagle 308 FBS, Dual Cam
2001 Ford Excursion 4.30 LSD,V-10,2WD,RAS,5-Star tuner
Honda EU2000 & EU1000 gensets;
2000 watt Tripp-Lite inverter/charger APS 2012
Saturn SD365 inflatable, 15 hp 2 stroke Yamaha
"Scout" Springer Spaniel
Almot
Vancouver BC
Posted: 10/28/11 11:15pm Link  |  Print  |  Notify Moderator
Small LCD TV draws around 50 watt. So you need a small 70-80 Watt inverter as they lose about 20% while inverting from DC to AC. So if it outputs 50W, it draws 60W from battery, this is 5A @12V. You will draw 15 AH from battery in 3 hours, which is nothing to people with big battery bank over 200 AH @12V. For somebody with one tiny battery it's a different story.
GMC4ME
Stockton, CA
Posted: 11/01/11 08:38pm Link  |  Print  |  Notify Moderator
Bottom line: Haul as many batteries as you can!!
ez2endo
Northern Illinois
Posted: 11/08/11 06:20pm Link  |  Print  |  Notify Moderator
OK Guys,
Thanks so much for the imput. Lots of good info. I got a 2000W MSW inverter from Farm N Fleet $189. 4 deep cycle marine batterys. Two were already installed (1 year old) 90AH each and two new deep cycle batterys 125AH each for a total of 430 AH. I am planning on running two cords from the inverter, mounted in the front compartment, to two new outlets installed in the trailer. One behind the entertainment center. The other outlet I was going to install somewhere outside that same cabinet to allow an inverter outlet for other uses. I am not interested in the micro or coffee pot, I can crank the genny for that when needed.
I have a 27" LCD TV 120W, Dish Network box 120W, a Blu-ray DVD player 25W, a VCR player 20W, an older AM/FM cassette CD changer Sterio 150W. 435 Amp total. Of course they wouldn't ALL be on at the same time, but several of them could be for sure. The TV in the bedroom would be nice to run on inverter power as well. I thought it would be easier running a dedicated 12v outlet to behind the TV now (isn't currently one there)and using an additional small plug-in inverter for that TV. I plan on boondocking in the desert in the winter then setting up in a campground somewhere for the summer months. I was just going to un-plug from the inverter outlet when on shore power and re-plug into the normal 120v service. I think it would it be wise to fuse the battery. 100 Amp? 200 amp? how do you know?
Could this be hooked up to the the main AC box so I just flip a breaker or two to change over to Shore power? I would also like to install some kind of meter or monitering station. a voltmeter at least an amp meter too would be better. Any suggestions?
Am I missing anything important?
Again Thanks guys!
pmoreton
California
Posted: 11/10/11 07:17am Link  |  Print  |  Notify Moderator
Hi all, I'm installing a Xantrex HF1800 MSW inverter. It has a 3 phase charger as well. However, I have a Parallex 7300 sieries converter that also has a single phase charger that is not efficient. I'm concerned that when shore power is supplied to the system, both chargers will be trying to charge my 4 Trojan T-105 6v's. Have any of you had this issue or can you suggest a resolution? Thanks!
Phil
