RV.Net Open Roads Forum: Tow Vehicles: PSD won't take a jump
Search only in Tow Vehicles
 > PSD won't take a jump
starlord
San Antonio, Texas
Posted: 10/30/11 09:08pm Link  |  Print  |  Notify Moderator
First, one battery probably is not enough, you use two to start it. Also, I am told that if they are not very good jumper cables it won't work either. I had that problem once....was the batteries.
N6761U
Eureka, CA
Posted: 10/30/11 09:41pm Link  |  Print  |  Notify Moderator
When you buy batteries don't scrimp, heavier is better, Interstate makes batteries for Costco, but are a lot lighter than theirs, go for more lead.
2oldman
Wilson Creek WA
Posted: 10/30/11 09:47pm Link  |  Print  |  Notify Moderator
Bingo. You need the fattest jumper cables you can find to start a dual battery truck.
chevor
US/Canada
Posted: 10/31/11 12:10am Link  |  Print  |  Notify Moderator
I had to jump my duramax once. It was last winter in -20 weather, left an assorsory on. It took a truck off the same size, 2 sets of #2 gauge wire jumper cables hooked to each battery and needed to charge about 1/2 an hour before the truck would roll over. I still have those batterys in the truck and they havent gone dead yet.
2010 Gmc 2500 Duramax,1ton rear springs, 90g box tank, 0ver 508,000 Odometer miles, 20k Curt fifth wheel, 18k Curt rear mount hitch. Cobra CB/Weather Radio, Bridgestone Duravis R500 HDs Rancho 9000 Shocks, Firestone Airbags, bypass oil filter, Fass 95HD
NavyDood
NW of DFW
Posted: 10/31/11 06:12am Link  |  Print  |  Notify Moderator
No you don't. Just hook up to the posts of the main battery and not the sister battery. This way you dont have to go through the extra cable in the parallel circuit. The Fords are always harder on batteries beacuse of the glow plugs and having to have a minimum rpm requirement before the injectors will pop.
Just because we have diesel engines doesn't really mean they take a whole lot more to turn over an engine. A V8 gas engine starter could require more juice from a battery than the one in my Cummins due to the way the starters are built.
My truck was built in Oct of 03. I am still on the original batteries and they spin it over just fine even after the grid heater has cycled in single digit temps.
- Retired Navy Chief
- Vanilla 04 2500 QCSB, 4x4, 48RE w/MagHytec DD, Smarty Jr, 4" Exh, Modded Air Box, Isspro Gauges, Quadzilla RPG w/fuel pressure, DynaTrac front, Coolant By-Pass Filter
- 06 Pilgrim 30RE2SLF-5 13,300lbs loaded. B&W Companion
2oldman
Wilson Creek WA
Posted: 10/31/11 09:05am Link  |  Print  |  Notify Moderator
So you're saying the cheapest, thinnest cables will start a car just as well as more expensive ones? That is not my experience.
And, you're also saying that an 8cyl diesel engine with a 14:1 compression ratio (or thereabous) doesn't *necessarily* require more battery current to start it?
You're on borrowed time with 8yo batteries.
* This post was edited 10/31/11 09:23am by 2oldman *
VinnyP
Bronx,NY
Posted: 10/31/11 09:39am Link  |  Print  |  Notify Moderator
Thanks again everyone for all the tips and suggestions. Two new Diehards and I'm "on the road again".
Honk when passing through The Bronx.
Vinny & Rita
The Bronx, NY
2013 F350 PSD CC
2012 Cedar Creek 36B4
wittmeba
Virginia
Posted: 10/31/11 11:01am Link  |  Print  |  Notify Moderator
Glad to hear it and thanks for posting back to let everyone know.
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 05/19/2013
mkirsch
Rochester, NY
Posted: 10/31/11 11:13am Link  |  Print  |  Notify Moderator
Just went through this yesterday with Dad on one of the tractors... Cummins 5.9L powered, by the way
He turns the key, it cranks over a few times, then nothing. Puts his best 2ga jumper cables on it. Nothing but clicks.
He's got a carbon-pile load tester. Puts that on, and the battery's got nothing. Meter drops to zero when he hits the load button.
Dang battery is only 5 years old. Back in the 1990's we were replacing batteries that were 15-20 years old. Now none of them are more than 3-5 years old.
Those carbon-pile load testers are a great investment if you've got several batteries to maintain. It takes the guesswork out of whether the battery is good or not.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
N6761U
Eureka, CA
Posted: 10/31/11 10:39pm Link  |  Print  |  Notify Moderator
Fyi, The batteries went dead in my 99 PSD a few yrs ago,( left the dome lite on for a couple of days (dummy here)), but my jumper box/compressor from Costco was able to jump it. My mechanic says he uses his all the time to jump diesels.
